Results 1 to 3 of 3
Thread: VS 5.0 Screaming like a Banshee..
    VS 5.0 Caprice S2
    Dec 2008
    Armadale WA
    Default VS 5.0 Screaming like a Banshee..
    Hiyas, First time posting and unfortunately its for a spot help rather than offering some.
    I've just walked out of the shops, jumped in my car (VS Caprice 5.0) and started it up only to have it scream and wail in protest. On the way to the shops there was not a whimper from it, this noise seems to have come out of nowhere. I've removed all the belts 1 by 1 (aircon, power steering, alternator/water pump) and it's still making the noise as soon as the engine starts. Thinking it could be the timing chain? Anyone have any thoughts?
    Any help would be much appreciated.
    Ian
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Could be the starter motor still in mesh with the ring gear - normallly the starter pinion retracts from the ring gear as soon as you release the starter, but it can get stuck in and still be connected to the ring gear making the starter motor rev and scream till it ....fails.
    VS 5.0 Caprice S2
    Dec 2008
    Armadale WA
    Cheers, I'll be taking a look tomorrow, just towed it home.. Thanks for the tip, I'll let you know how I go.
  1. O8 YZF Banshee Nearly New
    By wezza95 in forum Swap / Wanted to Buy / Trade
    Last Post: 29-10-2008, 06:32 PM
