Results 1 to 6 of 6
Thread: Airconditioning help please =]
    Vr acclaim
    Dec 2009
    Default Airconditioning help please =]
    In my vr and im guessing everyones vr there is a pipe that runs near the drivers left leg. Im guessing it is something for air conditioning, (obviously im no car genius).
    Well mine is always hot dont know whether that is normal even if the AC is turned off or on cold the pipe is always hot, Is that normal?
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    I think that is the heater core pipe mate, so its normal to be hot all the time
    150db in a commodore =
    Vr acclaim
    Dec 2009
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    It should only be hot if you have the dial turned to hot - if you dial cold there is a vacuum switch at the end of the dial that turns the heater tap off. If your pipes are hot, and the dial is on cold then this means you are mixing hot and cold air and getting warm air. The pipe should be cold when you use the A/C. Check other similar posts as this exact problem has been covered in the last few weeks.
    AU II Falcon
    Apr 2010
    Goulburn
    seraphic06's Avatar
    seraphic06 is offline Woodgrain Nut
    VS Esteem SII Wagon
    Sep 2008
    Adelaide, SA
    Quote Originally Posted by skelly View Post
    his pipe was boiling, one time i touched it and im now scared for life
    Well don't touch his pipe and you'll be alright...
  1. VX SS Airconditioning
    By Woody67 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-03-2009, 05:17 PM
  2. Airconditioning G
    By gsmrobinson in forum General
    Last Post: 13-12-2006, 11:10 AM
  3. Airconditioning Advice
    By gsmrobinson in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-10-2004, 12:06 AM
  4. Vt Airconditioning
    By emufriedchicken in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-02-2004, 09:42 PM
  5. Vr-vs Airconditioning
    By gsmrobinson in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-11-2003, 11:05 PM
