Results 1 to 7 of 7
Thread: VS Heater
    Dec 2009
    Question VS Heater
    I have recently purchased a Series III VS Ute and would like to know is it normal for the Heater lines (situated under the dash near the drivers left leg) to be constantly hot? I mean burning to touch hot? Is there a valve somewhere that should be shut if the heaters are not required?
    Rob
    alan smithy is offline alan smithy
    vs wagon
    Aug 2008
    footscray melb.
    no. it,s not supposed to be hot if you dial cold.open the bonnet, where all pipes join on left, that is the tap. first check if tubing is connected to the tap. that is vacuum line, if it is check by putting a finger over tubing, you should feel it sucking. if it appears to be ok the tap itself could be stuffed. i just replaced one from wreckers for $15. try these first.
    VS executive
    Jun 2009
    if its not sucking also have a look under the where the pipes are. theres a metal rod coming from the back of the temperature dial connected too a hookish white plastic lever , when its on full cold it should be pressing a button in all the way... mine wasnt doing this which caused the same problem you are having.
    i fixed it by jamming cardboard inbetween the lever and the button making it press all the way in ( temporary fix till i can ajust the hook thing without breaking it).
    Vee-ard's Avatar
    Vee-ard is offline QuickVR95II 2010 Survivor
    Foam Tuned VR 5.0l Ute
    5 Miles 2 Go Champion!
    Jun 2009
    Bayswater, WA.
    Uh pillzor? Not sure if its the same on the VS as the VR, but on mine, one side of that white plastic "hook" has a catch like a suitcase, and if you flip it down you can adjust where the white plastic thing holds the thread on the metal rod.
    The hall of fame:
    Quote Originally Posted by lindsay.VS.Wagon. View Post
    ....a mini spool creates greater airflow to the engine which means more oxygen into the engine which adds greater combustion which adds an all around performance upgrade.
    Quote Originally Posted by edals View Post
    Also found running your lights all the time looses 100kms to a tank also.
    ಠ_ಠ
    VS executive
    Jun 2009
    Quote Originally Posted by Vee-ard View Post
    didnt notice that, ill go double check in the morning.
    VS Executive S1 Station Wagon
    Sep 2007
    If you're talking about the Heater Tap here then do NOT get one from a wreckers. They're only $30 brand new and they should be replaced with a new one always.
    I had one of these break / snap in half while just undoing the ring clamp around the top hose facing the front of the car.
    Evil Evil little part.
    Quote Originally Posted by alan smithy View Post
    checkout myVS S1 Wagon here!
    Dec 2009
    Thank you all for your advice. Problem solved, give yourselves a pat on the back.
    Rob
  1. what is this? (something to do with heater?)
    By budgieVH in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 15-09-2009, 10:31 PM
  2. heater no hot air
    By sycvs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-08-2009, 12:11 AM
  3. air con/heater fan
    By Bunjey in forum Electrical Wiring / Questions
    Last Post: 06-03-2007, 10:17 AM
  4. A/C with heater ??
    By davey g-force in forum VY Holden Commodore (2002 - 2004)
    Last Post: 10-07-2006, 09:32 PM
  5. Heater No Hot Air
    By cuckoo in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-06-2005, 04:59 PM
