+ Reply to Thread
Results 1 to 15 of 15
Thread: greenfoam can u help
    vs ss
    Aug 2009
    reservoir
    Default greenfoam can u help
    my car wants to stall when i first start it it knid of feels like there is no petrol it does it when i start it when its hot or when i put it in reverse might need a tune
    VS Berlina 3.8
    Dec 2008
    I think the tune is the least of your worries.
    Checked your error codes? Or even better, does you fuel pump make a whirring sound when you turn the ignition to Acc.?
    vk.jonno's Avatar
    vk.jonno is offline :):):) vk.jonno Hitchhiker
    Vk commodore, hq one tonner, hj ute,
    Nov 2009
    south east
    youde probz get a response already if yu pm'd him..
    Quote Originally Posted by BIGbrown1 View Post
    Hey dea, financed my VS 3yrz ago, desper8 4a car, meter read 214,016kms... I PAID $14,000.00, 3yrz l8r im dealin with alot of problemz... n e cheap BUT good mechanix in west melbourne? n e info appreci8d... Fanx...
    Quote Originally Posted by Menace38L View Post
    yea if i end up getting it il lay low from the cops lol jus want it for skids etc lol
    TVR-190's Avatar
    TVR-190 is offline Temporarily Unbanned TVR-190 Senator TVR-190 Senator TVR-190 Senator
    WK Statesman V8
    Jun 2008
    Cronulla, Sydney - Australia
    http://forums.justcommodores.com.au/search.php
    no need to thank me, i do it cause i love this forum
    TVR awayyyyyyyyyyy
    TVR-190: That LSD service paid off. Stato just got very sideways.
    Grennan: In a stato, the term is held starboard.
    VP Executive R-spec
    Jan 2005
    Hi mate I don't go near any car that isn't running properly unless it's modifications that are the cause of the dodgy running. These cars are self tuning and I allways ask people to fix the problems before I have anything to do with it otherwise it's just sticking a bandaid on a sinking ship
    GetToDaChopa is offline Blues Brother # 2 GetToDaChopa Berlina
    The Blues Mobile
    Dec 2008
    Western Sydney
    False alarm Jason
    OP Might be to do with you air control unit (ACU)?, always forget the proper name for it. Does the car run ok when you push the gas pedal? but then almost stalls when you let go?
    burnz's Avatar
    burnz is offline dah dut dut da dah burnz Caprice
    2010 CRUZE Diesel
    Jun 2005
    springfield
    Quote Originally Posted by <TVR-161> View Post
    TVR awayyyyyyyyyyy
    better get you a cape hey (green is tvr cars colour) sooo green lantern is gone, kermit thats used.
    geez it's pretty tough getting a super suit.
    Research has shown that men usually sleep on the right side of the bed.
    Even in our sleep we happen to be right.
    Powered By Garrett
    vs ss
    Aug 2009
    reservoir
    its only really started doing it after i put the exhaust in checked error codes on the scat tool and nothing came up fuel pump ok injectors ok acu ok fuel reg fine fuel pressure fine everything semms to be working fine someone just mentioned that it might need a tune
    vs ss
    Aug 2009
    reservoir
    vs commodore
    Oct 2009
    Tamworth NSW
    Check for any set error codes.It will flash code 12 three times ,and then any error codes(if any are set)Checking error codes VR/VS (Revised)
    vs ss
    Aug 2009
    reservoir
    i already did that on the scat tool the full computer thingy magig and there was no stored codes in history or at that current time it did it again today when i was driving it out my garage
    VS_Pete_1's Avatar
    VS_Pete_1 is offline Donating Member VS_Pete_1 Berlina
    1997 VS II V6 Berlina Auto Wagon
    Dec 2007
    Can you leave the scanner pluged in and go for drive and see if it happens again?
    If it does you should get a code on the scanner. Good luck.
    "Success is the ability to go from one failure to another with no loss of enthusiasm" Sir Winston Churchill.
    My VS II Berlina Wagon
    vs commodore
    Oct 2009
    Tamworth NSW
    What sort of scanner is it.If its one of those cheap ebay ones,half of em dont work properly, and sometimes wont show if any codes are set.A mate brought one a few weeks ago,no errors showing up on the scanner,but errors were showing with the engine light test.apparently it was OBD11 onwards only.No good on a VR/VS.The people that sold it to him told him it would work on VR and later commodores.
    vs ss
    Aug 2009
    reservoir
    its one of those real expensive ones i use at my cousins business prestige autos in preston and it seems alright the problem is giving me the shits its also lacking a bit of power could it be faulty injectors or would it show up on the error codes
  15. #15
    vs commodore
    Oct 2009
    Tamworth NSW
    Dirty injectors will make it loose power and run like s--t, it wont show up in a diagnostic scan.
+ Reply to Thread
  1. Greenfoam or anyone...
    By grundy303 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-11-2009, 04:21 PM
  2. greenfoam????????
    By lukieboy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-12-2008, 08:30 AM
