Got another one for you guys in the quest to patch my ute up. Whenever I hit a bump, (it can be any size bump, right down to a small bump like a bridge expansion gap) I get a knocking from what sounds like the rear wheels, it also seems to be coming from the left hand side. Its a bit like a "KNOCK..knocknok" noise. If I had to guess, I would have said it sounds like the shocks are screwed and its bouncing off the top of the springs, and echoing through the empty tray. I got under the back and checked what bushes I could see, but couldnt see any breakage... Am I right in thinking the shocks are buggered? also, even if you think it isnt, whats the easiest way to tell if I need new shocks under the back?
Checked your swaybar links?
Also check your exhaust pipe hangers. Mine was recently banging in the rear over bumos and it was the exhaust hitting the panhard rod.
