my vs 5 litre, is struggling at high revs.
It drives fine if im easy on the pedal, but if i go to boot it, as soon as it gets in the high rev range it just struggles. The tranmission doesnt kick over into next gear.
Its driving me mad. i just had a new cam installed, and it was doing this before the cam as well. I have a tuned memcal for a stock engine, and it ran fine.
Could it be the tune? diff? tranny?
Define struggle? How old are the leads, dizzy & rotor button?
and 3 Dangerous non ABS VN's
No chance the catalytic converter is blocked? - an over rich mixture or excessive oil burning can block the matrix and kill high revs.
just got new leads. dont know about dizzy or rotor button. What exactly is the dizzy? Do you mean distributor cap? whats the rotor button?
Centre at the rear of the engine - all the leads go to itBut would not expect it to fail over night as such - so if the car was running fine into the high revs before the cam - I'd be going back to the mechanic that fitted the cam.
What cam did you put in - just a mild one?
maybe get the gearbox serviced. mine does that on cold starts, it doesnt wanna change into second in boost until i back off..
but ive been told that people have had simular problems, had the gearbox serviced and a trans cooler and it was fine after that
Vortech V1 supercharger : 10psi : Intercooled : 3.89 Mini-spool : VT Big Brake conversion : Shift kitted auto : B&M Shifter
My VS CLUBBY!
237.2RWKW - 318.1HP - 926.4 NM
I was goin to suggest fuel filter, how long since you changed it, also could be the pump.
im going to get a fuel service and tranny service from ultratune. ill see how it goes. im sure it will solve the problem.
Noi cant recomend any in particular, I jst replaced mine with a new factory spec one when it fugged up on me. My car kept reving to about 4500rpm and dogging out on me and wouldnt rev any harder.
I just think it's not able to reach the speed it needs to reach to change gears at full throttle (it will need to go to at least 5200) so it sounds like it's a power issue rather than the gearbox, If it's not miss firing as such the top two on the hit list would have to be fuel pump or filter but mostly a colapsed cat.
The cam is the crane 260, very close to a stock cam
perhaps a vacuum issue or the auto
Just changed the air intake back to the stock over the radiator one this morning.
It seems the problem has gone now. I had a pod on there before and also tried a custom cai that i made.
I believe they were sucking in too much hot air. My engine bay gets pretty hot when driving. Also noticed a massive drop in temperature on the guage and stays between a quarter and the middle. Prior to this, whe i was running with the pod and custom cai, the temp would be around the half way mark.
I gave the car a good booting this morning, and didnt struggle at all. While I was at it I saw a blue vs the rego is vs3551 , Anyone seen this guy around before? That thing was a monster
certainly am. appreciate the help everyone. will post again if i do find other symptoms
damn. the problems still there. Have booked in to get checked, the fuel system, dizzy, everything. How can i check if the cat has collapsed? Is it an easy fix, temporary fix like take the internals out?
I hope its only the fuel pump or something.
I'm totally spewing at the moment, I would get thrashed by a datsun...
