Results 1 to 22 of 22
Thread: Car uses more fuel than my old magna, dire situation!
    Paiste402's Avatar
    Paiste402 is offline My workin on the car face
    1992 EB Fairmont Ghia
    Oct 2007
    Normanville SA
    Default Car uses more fuel than my old magna, dire situation!
    My VR is chewin the juice. I get around 400-450 to a tank on purely highway driving with 98 octane premium and me taking it easy. No codes from the ecu, its a fully serviced car with new plugs and leads and starts and runs fine. seems a little down on torque but i used to have V8's. Ive got a chrome tip on the exhaust and it goes very sooty very fast. i cleaned the exhaust tip yesterday morning after doing the leads, did 100kms that day and i could already get soot on my fingers. If i leave it for a week it starts to go black until soon enough solid black. anyone here had this and fixed it?
    cheers guys
    Quote Originally Posted by <TVR-161> View Post
    yeah vts are becoming the new vn here, seing plenty with rear stockies, front chromies towing invisible caravans.
    Mar 2009
    VS Berlina 3.8
    Dec 2008
    Mar 2009
    Quote Originally Posted by _R_J_K_ View Post
    "Car uses more fuel than my old magna"? It should be pretty obvious why.
    and this is helpful how?
    VS Berlina 3.8
    Dec 2008
    Quote Originally Posted by westbad View Post
    Need I explain why his heavier Commodore with a bigger engine uses more fuel?
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Magna's were horrible on fuel. So the commodore being worse is a problem.
    I'd replace the o2 sensor first and check the ECU temp sensor too.
    and 3 Dangerous non ABS VN's
    Paiste402's Avatar
    Oct 2007
    Normanville SA
    lol please mate, my old 1992 4 cylinder magna wagon with a carb used so much and it was even a manual cause i had to thrash the thing to get anywhere, engine size doesnt mean good/economy. My old 308 was the most economic car ive had cause it was so well serviced and a fresh rebuild and driven well. I know my VR is running rich i just gotta get to the bottom of it, and i though O2 sensors gave codes when they pack it in?
    VS_Pete_1's Avatar
    VS_Pete_1 is offline Donating Member
    VE II SV6 MY12 Sportwagon
    Dec 2007
    About 80,000k you should change them I think it is.
    "Success is the ability to go from one failure to another with no loss of enthusiasm" Sir Winston Churchill.
    My VS II Berlina Wagon
    MY12 II SV6 Sportwagon
    Mar 2009
    o2 sensor wont give out a code until it dies, it could be faulty, they have a service life of about 50,000- 80,000km for the cost of a new one ($50-$100) its worth changing, it will pay for its self in wasted fuel your using now if that is the problem, and you say there is a heavy sutt build up which would suggest running rich so that would be the 1st thing i would change then if still no different i would then look at the coolant temp sensor.
    Paiste402's Avatar
    Oct 2007
    Normanville SA
    ah right no worries, i should be getting some good dosh soon and i will replace both while im at it
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    400 -450 on a tank may be OK - it depends on how you define "highway driving" = to me it's on tollways and maybe motorways...sometimes at 100kph and at other times slowed to 60kph. If this matches your definition of highway driving then I'd say you are getting average economy.
    When the 4 cylinder Magnas were on the market, their main selling point was that they used less juice than Commodores and Falcons, so I agree with _R_J_K.
    Paiste402's Avatar
    Oct 2007
    Normanville SA
    na country driving, 100kph all the way on roads. sure there are hills n such but my old EF falcon got 800kms to a tank, this VR is getting half which isnt right at all.
    vs commodore
    Oct 2009
    Tamworth NSW
    How much stuff do you carry around in the boot like toolboxes etc.More weight uses more fuel.I dont fill the fuel tank ,just go to half a tank,otherwise you just have to drag around a heap of extra weight in fuel,especially when just driving around town.I fitted a set of pacemaker tuned length headers and they made it a lot better on fuel (its a VS V6).Made it drop the running temp on the gauge as well,dropped about 1 mark from where it used to run at.I'm not sure if this hepled to make a difference on the fuel usage or not though.And tyre pressure,run em at 32 psi.Check the tyres maximum pressure first though.This is for the standard 15 inch chaser rim.Some alloy wheels will run at a higher pressure than the standard rims.Anyway try running them at the maximum pressure or there-abouts.
    Paiste402's Avatar
    Oct 2007
    Normanville SA
    this is with the car empty, a spare in the boot and me in the car. ive got 17'' clubbie mags but im not sure what PSI they are 'supposed' to be running. but its deffinatly running rich, slightly down on power and a sooty exhaust
  15. #15
    vs commodore
    Oct 2009
    Tamworth NSW
    Id be looking at the oxygen sensors as stated previously.And check the air filter,if its blocked it will cause the engine to run rich.
  16. #16
    Verynice's Avatar
    Verynice is offline Band
    VS Caprice 5L
    Aug 2008
    SA - The Backwards State
  17. #17
    Paiste402's Avatar
    Oct 2007
    Normanville SA
    Quote Originally Posted by Verynice View Post
    just sell it and get that super sweeeeet falcon
    what do u think im trying to do
  18. #18
    Mar 2009
    Quote Originally Posted by Paiste402 View Post
    surely things cant be that bad that your thinking about buying a ford!!!
  19. #19
    Paiste402's Avatar
    Oct 2007
    Normanville SA
    sadly im being quite serious, my VR is good. If i fix a couple of tiny things its as good as a VR can get without going aftermarket. But the falcons are just so much more polished, ive owned one and got rid of it for this VR and i miss it every day. And i like the ford 6 MUCH more than the buick V6. more Australian and just more refined.
  20. #20
    vs commodore
    Oct 2009
    Tamworth NSW
    The 6 cylinder falcon motor is s--t.Ive replaced more ford 6 head gaskets than I care to remember.I wont do em any more .Its just a waste of time.6 months later they are back wanting it fixed again.They just seem to blow out for no reason.And it just seems to be the automatic trans ones that do it,very strange.
  21. #21
    Verynice's Avatar
    VS Caprice 5L
    Aug 2008
  22. #22
    Paiste402's Avatar
    Oct 2007
    Normanville SA
    and while your at it, sell the paistes and get some zildjians lol. jk
    oh they are long gone mate, they were cheap Paiste-402's Now im rockin Sabian AA's
  1. need advice on this situation please
    By minitsbay in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-06-2009, 12:23 PM
  2. Car Prices with Economic Situation
    By Jesterarts in forum The Pub
    Last Post: 07-05-2009, 07:15 PM
  3. [VIC] FS. 1992 Magna $250
    By kohan in forum Vehicles For Sale
    Last Post: 06-04-2009, 01:38 AM
  4. [VIC] FS: 99 TH Magna V6
    By lad79 in forum Vehicles For Sale
    Last Post: 10-02-2009, 07:52 PM
  5. This may save your life, situation awareness scenario
    By Doctor Sodways in forum Jokes/Humour
    Last Post: 28-06-2006, 12:27 PM
