Results 1 to 6 of 6
Thread: Variable p/s rack vs normal, any difference?
    Vr Executive 3.8
    Dec 2008
    Default Variable p/s rack vs normal, any difference?
    Hey guys
    (car is a vr v6)
    The other night the left side of my power steering rack fell apart as I was leaving work, I had another steering rack sitting at home that dad got with his super sedan, both racks look identical except the new one has Variable stamped on the tag.
    Is there any difference between a standard rack and the variable one? is it ok to be using the variable one in my car?
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    Variable ratio rack should be OK, the variable one is nicer to drive thats all. If it fits its OK. You're not talking about speed variable are you ? I believe these have an electrical connection and can only be used on Hi series cars such as Calais.
    Vr Executive 3.8
    Dec 2008
    Theres no electrical connection and physically looks all the same so I'm guessing it will be sweet
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    The standard poverty pack steering rack is the variable ratio rack and pinion unit.
    Like greenacc says, the speed variable (Bosch Variotronic) has electrical connections and needs the higher BCM or whatever.
    STEALTHY™'s Avatar
    STEALTHY™ is offline So Wet For You!
    VP Calais International, VP Berlina LX Wagon
    Jan 2005
    SA - The Roadworks State
    If it is infact a variable speed rack, you'll also need a different pump, so keep that in mind.
    Quote Originally Posted by davway
    Improved Suspension Reduces Handling!
    Quote Originally Posted by JONNNNOOOOO!!
    cheers sexy
    VR Caprice
    Dec 2005
    The Variable will sit straighter so if you extractors it will not fit, also you need the whole Steering assembly or the lower steering shaft as they are different lengths.
  1. difference between fe2 springs and Normal
    By davenmarcia in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 15-12-2009, 07:00 PM
  2. Variable Int Wipers mod + BCM question
    By VrWagz1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-08-2009, 10:43 PM
  3. Variable effort or variable ratio?
    By Timo in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-10-2007, 07:44 PM
  4. variable intermittent wipers
    By unregistered in forum VY Holden Commodore (2002 - 2004)
    Last Post: 25-01-2007, 01:30 PM
  5. variable speed rack
    By webwombat in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-12-2006, 11:07 PM
