Results 1 to 6 of 6
Thread: Removing Rear Shocks
    edals's Avatar
    edals is offline Blues Brother # 1
    VY 2002 Wagon, VX 2001 Sedan
    Sep 2008
    QLD/NSW Boardish
    Default Removing Rear Shocks
    hey All,
    Replacing the rear Shocks in a VR Sedan, now i get how to do it, just regards to jacking the car up, if i jack it by the diff, the shocks are still going to be compressed, what if i just jack one side up at a time and replace it when one wheel is off the ground? . any help would be awesome
    cheers
    vs commodore
    Oct 2009
    Tamworth NSW
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    You should be able to compress you shocks by hand, depending on how old/stuffed they are they shouldn't try to spring back much, you new ones probably will try to expand back out but its usually pretty easy to hold them down, just don't waste all your energy trying to compress them quickly cause it wont happen.
    edals's Avatar
    Sep 2008
    QLD/NSW Boardish
    Ok Easy as, Yeah i can compress the shock, just was not sure about jacking the car up. Cheers guys
    VYMAD's Avatar
    VYMAD is offline SILVERFOX
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    Yeah Edals, pull off one wheel at a time and do the job that way. Peice of piss mate hey and the new ones are easy to compress to where you want them for fitting the bottom bolt.
    edals's Avatar
    Sep 2008
    QLD/NSW Boardish
    Thanks Guys, New shocks are in. after a few attempts lol. First i removed the first one, cool simple, then found out the guy from otobarns gave me ones for IRS so had to get replacements, then fitted, easy, 2nd shock, the flat tip to stop the shock spinning while removing the nut broke off, then required a angle grinder lol
  1. rear shocks etc
    By Brucefromruse in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-12-2009, 07:54 PM
  2. Rear shocks
    By King_berald in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-04-2009, 01:33 PM
  3. removing shocks & springs
    By macksvt in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-10-2008, 02:46 PM
  4. VS Rear Shocks
    By Robbo.Qld in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-03-2008, 08:16 PM
  5. WTB lowered rear shocks suit solid rear axle
    By VS SII in forum Swap / Wanted to Buy / Trade
    Last Post: 21-03-2006, 09:27 PM
