hi guys.. just after some advice if youve got the time... got a hsv 96 clubsport.. has never missed a beat until the last few weeks where youll be driving along and it cuts out random while driving.. usually pull over.. have to crank it a few times with no luck.. then.. just as im about to ring the towey.. she kicks over and gets me home.. have replaced the fuel pump and fuel filter.. the problems still occurring.. have read previous posts and they say something about checking code errors?? how do you do this?? have worked on cars all my life.. doing ground up rebuilds on hq 1 tonners,geminis,calais,etc..and always learning new things... so sorta know what im looking at.. any help in diagnosing this problem would be much appreciated.. cheers.. suzi![]()
Crank Angle Sensor ?? check your error codes here :
Checking error codes VR/VS (Revised)
Hey mate ive just had the same probelm in my 5.0L it was the ignition module for me, it was shitting itself and it will work on and off, once it cools down it works again. Common problem in vs's around now. Hope this helps man
thanks heaps guys.. am just about to go out and do the error code tests... and am taking the ignition module into consideration to.. cheers dinwoodie..![]()
ok.. so the error codes have come back 12..ok.. have replaced the fuil pump,fuel filter .. efi and fuel pump relays.. shes still cutting out... but now starts again first kick when you restart it... no problem at all to start .. just now.. cuts out randomly while driving.. either cruising along at 60/70 or slowing down to come to a stop.. any further help will be appreciated.. looking into the crank sensor to although im still to find where it is on the 5.0l... lol
no crank sensor on the 5.0. Sounds like your loosing power somwhere.
I'd still replace the crank angle sensor.
Im pretty sure there's a CAS on the 5L.
Ignition module............................................ ....................................
Similar thing just recently happened with my VR senator. Its had a shitload of little problems, things the mechanics cant always get a hold of.
This has happened recently. I have an lpg/petrol system. Engine died on swapping from lpg to petrol. Restarted after a few cranks, drove 200 odd metres on petrol and it died again. Let it cool down a bit and restarted, swapped to gas,m and got home. Haven't driven it since then.
Also, recently, has been having losing power during acceleration sometimes, almost feels like its misfiring, not getting fuel and it sputters, then picks up. Its depressing really. I wish i knew more about cars, but atm, i have to rely on the mechanic, and thats just slow. They cant seem to get it right, and when i get it back, something else is wrong with the thing.
If anyone has anymore suggestions for this problem, would be appreciated.
Hey mate i replaced my ignition module and the car worked fine for a week or so and now i am having the exact same problem as you. I found if i tryed to start the car right after it gives me a code 12 it will start. The auto elecs think its the BCM but it's still there getting worked on so ill keep you posted
Same issue on VS V6 auto 6/96. Wait for 5 mins & starts again.
Changed computer over was good for a while. Now back to square one. Am thinking fuel filter, crank angle sensor.
Will check vehicle immobilizer light next time it cuts out. This needs to go out when igition on. Also listen to hear fuel pump start up at igition on.
What's the cost to have crank angle sensor replaced by mech ?
Kind Rgds
Dave
The V8 does not have a crank angle sensor.It has a hall effect sensor in the distributor instead.
Hey mate got my car back all running, it was the Hall Effect Sensor in the Dizzy, it's the 5.0L's version of a crank angle sensor had all the same problems you did and this fixed it, this issue is getting more and more common with the 5.0L's around now, gl mate
i have a 95 v6 vs commodore, i recently had 6 new spark plugs installed. ive done 205,000kms in the beast. was running fine.
the other morning on the way to drop the girl off at tafe and it just stopped dead, died steering lock the works. kicked it over nothing.
got a mate who is a diesel mech, checked fuel lines pumps etc couldnt work it out. that afternoon it kicked over fine and drove home, next morning was dead as a doornail. it kicks over but wont fire up.
ive done the error code check came back with code 12, meaning all good. i watched it for 15 mins to make sure.
ive tried the old trick of holding the unlock doors button and trying to start it, it worked but she died straight away.
some more info on the crank sensor would be appreciated.
cheers, paco
