Results 1 to 4 of 4
Thread: rear sway bar
    sprayzz's Avatar
    sprayzz is offline sprayzz
    vs commodore
    Dec 2007
    Default rear sway bar
    hey guys when i go around corners i hear a clunk in the rear end plus my rear left inner tyre is bold now i have had a look and i think its my sway bar rubbers.is this an easy fix? if you guys think it could be anything else would be much appreciated.
    cheers mark
    vs commodore
    Oct 2009
    Tamworth NSW
    Have a good look at all the bushes on the control arms(upper and lower).lever them with a long screwdriver and see if theres any movement in them. And also check the sway bar bushes.If they look old and cracked and out of shape then they need replacing.I use nolothane type bushes instead of the rubber ones.They last heaps longer and they give good road feel back through to the driver.
    sprayzz's Avatar
    vs commodore
    Dec 2007
    yeah mate i have checked all bushes and they move etc when i move car from side to side...is it easy to replace but what i can see it seems pritty straight forward.
    HSV VZ LS2 Senator
    Jun 2006
    Sydney/NSW
    worn out upper control arms on VN-VS commies is a common problem and pairs with new bushes can be bought quite cheaply on ebay.
    Commodore VK VL VN VP VR VS Upper Control Arms Rear NEW - eBay Other Lights, Indicators, Lights, Indicators, Car Parts, Accessories, Cars, Bikes, Boats. (end time 25-Jan-10 22:54:22 AEDST)
    When you replace them "only do one side at a time because" if you undo both together the diff/axle will move out of place and it will be difficult to refit the bolts back in.
    HSV VZ LS2 Senator, Stealth2 cam 307rwkw.http://forums.justcommodores.com.au/...ados-blue.html
    VS11 Berlina L67 super6 wagon 196rwkw. http://forums.justcommodores.com.au/...ified-cai.html
  1. VT Commodore rear sway bar.
    By My99VTACCLAIM in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-09-2009, 08:04 PM
  2. Replacing Rear Sway Bar Link Bushes.
    By Ozzie in forum General
    Last Post: 23-07-2009, 09:20 PM
  3. Rear sway bar
    By SAMO-87 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-11-2008, 01:23 PM
  4. wanted whiteline rear sway bar 4 vk
    By VK1981 in forum Swap / Wanted to Buy / Trade
    Last Post: 14-01-2007, 10:03 PM
