Results 1 to 5 of 5
Thread: VT v6 manual box into vs auto v6
    Nzpure's Avatar
    Nzpure is offline VS L67
    1997 Vs Supa6
    Aug 2008
    Christchurch
    Default VT v6 manual box into vs auto v6
    how hard is it to do?
    You Must Always Remember to Blow on the Pie
    ""Safer Communities Together""
    BIG DYL's Avatar
    BIG DYL is offline BIG DYL
    1998 VT Berlina
    Dec 2009
    adelaide
    Talking
    should be easy coz its the same engine the only problem you might have is the mounting but you can get i enginer to make a cutom mount witch is legel witch should cost $150 to $250 to get made up... hope this helps
    wamboin23's Avatar
    wamboin23 is offline Donating Member w/ Boost
    VS Calais - L67 + T5 | VR Acclaim V6
    Apr 2009
    Wamboin, NSW
    bolts straight up, same mount, or the one with the manual will work. not sure about the electrical side, but you'll have to wire up the reverse lights, and speedo possibly, and bypass the start inhibitor.
    then you've got the pedal box, master cylinder change over etc.
    supercharged vr 5 speed
    Jan 2010
    it will bolt straight up i just put a vs getrag into my vx. the vx was already 5 speed but the linkage arms at the top of the box are longer on the vx to the vs so make sure u get the vs linkage arms
    VSSECO is offline Underdog rebuild
    VS - 6 pots, 5 cogs
    Aug 2007
    VIC
    A series 3 VS ute is what you want to find. As already stated everything will bolt straight in I've done it myself. If you have access to a pit or a hoist and a few guys to help then you can get it done in a day. In your shed it might take a couple of days or more depending on your confidence level.
    If you go ahead with it then put the pedal box in before the big day, from memory it took a full afternoon to put the pedal box in. Most of the dash had to come apart to move heater pipes out of the way etc, the brake booster had to be undone as well.
    Electrical side... you will either require a full manual loom and computer to rewire the engine (then you will still need to bypass the auto inhibitor switch so the thing will start, the bcm needs to think that the car is in neutral or it wont start) OR the other option would be to hack up the auto engine loom and get a memcal written for it with the auto functions switched off (this requires a fair bit of messing around as far as I'm concerned but if you cant find a loom and computer then you have little choice)
    *** FOR SALE ***
    4.2L Buick V6 Billet Stroker - Built for big boost
    HUGE $$$$ SPENT - Selling well under half of the build cost
    http://cgi.ebay.com.au/ws/eBayISAPI....STRK:MESELX:IT
  1. Vr auto to manual using Vs manual/comp
    By Chris E in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-06-2010, 07:20 PM
  2. Please Help, Doing manual conversion and i used the auto flexplate bolt on manual fly
    By xtreme_sony in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-06-2009, 08:52 PM
  3. VN manual now with a VR Series II motor w/auto loom but a manual. Crank'n issues
    By Illuminatis in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-03-2009, 07:03 PM
  4. Auto or Manual?
    By VKCalaisReplica in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 28-10-2008, 09:56 AM
  5. auto to manual
    By mickla in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-09-2008, 02:38 PM
