Results 1 to 11 of 11
Thread: wheel cambers
    VY Executive
    Jul 2009
    Default wheel cambers
    i own a 1995 VS berlina and have noticed its cambers for all 4 wheels seem to be getting more angled. (if thats the right term). i dont really have a picture to explain it but say instead of the wheels being straight like this |----| they are looking more like this /----\ .tires i replaced on the rear 1 year ago are now completely bald or wire from the tire insides is visible. i thought it might have something to do with the cars IRS but its not just the rear tires doing this. anyone know what could be causing this?
    Jesterarts's Avatar
    Jesterarts is offline Your freedom ends where mine begins
    2005 HSV Z R8 Manual
    Nov 2005
    Mornington, VIC
    Is it lowered? That would explain the rear camber.
    The front camber shouldn't be that bad even if it has been lowered. Stut tops could be worn or collapsed maybe, the struts themselves could have be collapesed.
    OH, that reminds me, I had a similar issue with my e30, make sure the nuts at the top of the struts are not loose.
    Could be the strut towers have been damaged, a suspension place should be able to measure the distant between the 2 towers and see if it's less than factory spec.
    Some pictures would be good to see the magnitude of the issue.
    Front on of the front wheels and strut towers.
    Might help work it out.
    Good luck.
    VY Executive
    Jul 2009
    its not lowered at all stock as. ill try and get some pictures now. symbols dont really demonstrate the problem well do they? :P
    VY Executive
    Jul 2009
    ok here are the pictures. unfortunately pictures of the car don't really demonstrate how bad it is but hopefully you can get the idea from these.
    front tire with wire showing
    old front tire, completely eaten away
    obviously because the car sits on such an angle the only part of tire that contacts the road is the outer edge. eating away the tires very quickly
    Mar 2009
    get a wheel alignment as soon as you get some new tyres on it, that should fix the problem on the front, IRS rears always seem to chew tyres but you can buy a camber kit to help this.
    VY Executive
    Jul 2009
    im looking at selling the car soon and this is just one of the problems with it that i need to fix before selling it. ive got a set of its original 15s that arent chewn up to chuck back onto it for a wheel alignment. hopefully this will fix the rear problem too. but other people ive talked to have said that the rear problem will be expensive to fix.
    95 VS calais, 93 VR S ute, 99 VT HSV XU8
    Nov 2009
    the rear camber isnt real exspensive to fix its only 2 bushes and i only paid bit over 300 for springs and camber kit so the camber kit cant me to expensive only hard part is getting the old bushes out
    If You Want More Inches - Stroke It!!!
    Mar 2009
    No point at all getting a wheel alignment with 15's on it if your planning to put bigger wheels straight back on it, it needs an alignment with the wheels that are going to be staying on it.
    Jesterarts's Avatar
    Nov 2005
    Mornington, VIC
    I think that car needs a front end alignment full stop. I don't have what size rims he's running on the front, that should not happen.
    I was running 19's with SL's in the front and there was basically no camber wear on the front.
    The rear, well, welcome to the world of Holden pre-VE IRS...
    VY Executive
    Jul 2009
    i was running 18s all round but will be selling it with its original 15s. so they are the tires that will be on it when its wheel alignment gets done. it has been a while since ive driven the car but i remember it making a whirr vibrating sort of noise throughout the car when driving between 50-60kmh. i know this could be a million different things but is it possible that this was due to the way the tires were sitting on the road?
    Jesterarts's Avatar
    Nov 2005
    Mornington, VIC
    Whirring noise could be stuffed front bearings... but they shouldn't be causing front camber... You've wheels would fall off if the bearsing a re stuffed enough to cause negative camber... lol
    Not sure the excess camber would cause the tyre tread to be more noticably noisy.
    Best bet, take it into an alignment place, see what they have to say about the front.
  1. Which Wheel ?
    By guss in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-06-2011, 06:43 PM
  2. [ACT] FS: VL Calais wheel, have a calais wheel as your spare.
    By 6cylpwr in forum Parts And Other Items For Sale
    Last Post: 02-12-2009, 08:35 PM
  3. Wheel nuts off, but wheel wont come off?
    By cds in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-11-2009, 09:37 PM
  4. wheel
    By james90vs in forum The Pub
    Last Post: 24-11-2009, 06:07 PM
  5. Your thoughts on replacing steering wheel with airbag to a MOMO wheel....
    By *VOLATILE* in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-02-2006, 08:36 AM
