Results 1 to 10 of 10
Thread: fuel consumption
    vs berlina s2
    Feb 2009
    Default fuel consumption
    my 97 vs s2 v6 berlina is having a few problems atm.....
    its using around 200km of fuel in the city and about 300/350 on the highway...changed the coolant temp sensor, plugs, leads, has a new k&n filter 21/2 inch catback redback exaust.. new fuel filter, its always used to that fuel from when it was standard. brought it with 142,000km about a year ago now it has 175,000km on the clock...id really like to get the fuel useage back down. it has a vt auto with that makes any differents....also in the town i dont notice the check engine light coming on but out on the highway with cruise on at a 100kmh it seems to come on for periods of time then goes out......it also at times as u come to a stop will almost stall but it catches itsself and gets out of the stall at times its very hesitant at taking off as well feels like its going to stall... if anyone has anyideas please let me know its starting to drive me stupid
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    o2 sensor......
    and 3 Dangerous non ABS VN's
    Mar 2009
    check your fault codes but i should almost certainly say your oxygen (o2) sensor has failed, a replacement is around $50-$100 and should only take you 15 mins to fit.
    VS executive
    Jun 2009
    vs berlina s2
    Feb 2009
    ok i did the error code check and i got
    Code 76 - Air/Fuel ratio variation between left and right banks
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by fonzo View Post
    O2 sensor is looking the issue.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Or dirty injectors, plugs,leads or inlet/exhaust manifold gasket leak. I'd test the 02 sensors before replacing otherwise you may be throwing your money away. Gregorys has a fairly simple test of the 02 sensors.
    Mar 2009
    Quote Originally Posted by hako View Post
    what does the manual say mate??
    jono1492 is offline DTD
    VE omega
    Dec 2009
    Forrestfield, Perth
    I'm having the exact same problems with my '93 VR station wagon, how do I go about checking the 02 sensors?
    cheers
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Attached is the test. I should add that I've never tested them and simply replaced them. To be honest, on the 3 occasions I've done this (N13 Pulsar, EB Falcon and VS Commodore), no real improvement was noticed. This is why I've suggested you actually test before you replace - this way you get a better understanding of what goes on.
    Attached Thumbnails Attached Thumbnails fuel consumption-02test1.jpg   fuel consumption-02test2.jpg
  1. vy ss fuel consumption
    By Conn in forum VY Holden Commodore (2002 - 2004)
    Last Post: 14-02-2009, 12:22 AM
  2. fuel consumption?
    By quikvskiwi in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-09-2006, 12:30 AM
  3. fuel consumption
    By timboco in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-07-2006, 10:51 AM
  4. This is BAD fuel consumption
    By mag in forum VL Holden Commodore (1986 - 1988)
    Last Post: 20-06-2006, 11:10 PM
  5. Odd fuel consumption
    By Takhuma in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-06-2006, 12:12 PM
Tags for this Thread
