Results 1 to 14 of 14
Thread: need link to level 3 cluster conversion cant find it
    sycvs is offline commo for life
    vs executive
    Jul 2009
    phillip island
    Default need link to level 3 cluster conversion cant find it
    as the title says i need the link or name of thread i cant find it cheers guys
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    tripin.
    That will be the one.
    and 3 Dangerous non ABS VN's
    vs executive
    Jul 2009
    phillip island
    vs executive
    Jul 2009
    phillip island
    88GreenVN's Avatar
    Jun 2006
    in making the looms up - not that I've found. I made a jig up and took a few months to work it all out using a loom that had been made up for me. Takes about an hour to join in all the L3 wires.
    Strip a L3 loom and cut the 4th plug out along with the switch block plug where they join into the mail dash loom.
    Then solder into your L2 loom.
    vs executive
    Jul 2009
    phillip island
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by sycvs View Post
    i just picked up a 4th plug so do i need more then that
    Yes the switch block plug. Then follow the wire diagram in the tripin thread.
    vs executive
    Jul 2009
    phillip island
    88GreenVN's Avatar
    Jun 2006
    what does the switchblock look like and could i get away with it
    The trip computer has 3 modes. With out the switch block your stuck on what ever it was last set to. The switch block is the same fit as the speed alert.
    vs executive
    Jul 2009
    phillip island
    88GreenVN's Avatar
    Jun 2006
    i never use the trip meter but will the odometer still work with out it
    Yes the ODO will work without the switch block. You will see the odo reading when the car is turned off. Unless it happens to be on that mode.
    vs executive
    Jul 2009
    phillip island
    got every thing wired in except switch block what else oes the switch block change on the lcds
    88GreenVN's Avatar
    Jun 2006
    the 3 screens roll through 3 modes and have a total of 9 readings between them.
    The switch block is easy to do. 4 colours to 4th plug, brown white to a brown white and black to a black and you can connect a SB.
    vs executive
    Jul 2009
    phillip island
    so some plain switches will do it
    then
  1. Installing A Vr Instrument Cluster Into A Level 1 Cluster Vn Exec
    By badly_drawn_boy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-07-2011, 02:41 PM
  2. level 3 cluster conversion 1993-1995 vr ss
    By crockettntubby in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-01-2010, 08:40 AM
  3. Dropping Level 3 Cluster into unready Level 2 ready VS
    By VS Omega in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-01-2009, 03:56 PM
  4. Please find link attatched
    By Cursed CX8 in forum Site Feedback / Site Problems
    Last Post: 26-03-2008, 07:22 PM
  5. Vr - Vs Calais Level 3 Cluster Conversion Kit
    By petezor in forum Parts And Other Items For Sale
    Last Post: 30-09-2007, 03:38 PM
