need contact number for green foam, have emailed him etc.
car not starting, possible memcal/ignition issue
cheers
chris
if u have a memcal from him, try the original one to see if it fixes the possible memcal/ignition issue
he's already done, memcal for it, mechanic said igniton module has packed it, as it may not be able to hanlde the tune. and have already pm'd him. cheers
get a new ignition module then, i got a tune off him to and had no problems at all cant see his work causing the problem..
im not saying his work has caused the problem, i just wanted to no if i would need a high perfromance module to handle the new tune as i dont want to replace it with standard one and have it die again. was just after some info from him, as it could be as simple as it has just packed it in as i was driving on a hot day or its just wear and tear.
All good guys, the Dizzy fell apart and broke the hall effect sensor. Just for future reference a tune wont break the car <
