Page 1 of 3 123 LastLast
Results 1 to 25 of 67
Thread: changed oxygen sensors, now seems to be wasting same amount of fuel if not more!
    vs calais
    Dec 2008
    Default changed oxygen sensors, now seems to be wasting same amount of fuel if not more!
    hello everyone,
    well my vs calais v6 been chewing abit of fuel lately, so serviced it and changed the o2 sensors..
    i reset the ecu aswell
    but now the car seems to be wasting same amount if not a bit extra according to the trip meter
    anyone got any ideas/info?
    does the computer now need to adjust again or does it not need to adjust from a ecu reset?
    cheers in advance
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    most likely the engine isn't getting upto temp or the ecu thinks the engine isn't getting upto temp. does the dash temp gauge come up to operating temp at all?
    possibly may need to change the temp sender for the ecu.
    what is the consumption average on the trip comp?
    the ecu will adjust itself after a reset but you should notice a change from the old O2 sensors immediatly.
    if your going to change the temps senders you may as well change the thermostat whilst your at it, save you dropping the coolant twice
    Body by Holden, Soul by Brock
    the Legend will live forever
    vs commodore
    Oct 2009
    Tamworth NSW
    vs calais
    Dec 2008
    ive checked the temp sensor and resistances are correct to appropriate temperatures..
    also the car does come to operating temperature
    vs calais
    Dec 2008
    checked error codes and there are none only 12,
    getting an average of 16.5 around city driving it pretty easy
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    If you drive with a heavy right food it's still a little heavy but wouldn't surprise me.
    Reaper
    Reapers Black VP SS
    0-60 mph = 5.39 Sec, 2.30 60'
    Quote Originally Posted by skruba View Post
    practice makes perfect dude i was (still am) my bros guinea pig,he has been tattooing for near 2 years.
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    16.5 is still in the normal range for town driving, i average around 12 - 13 not driving hard or easy. with a mix of town and highway is goes down to 9.
    Have you tested the new o2 sensors? they can still be faulty out of the box, ive had a few before. Hows the car otherwise in general? fully serviced? Fuel and air filter in good nick? MAF sensor might do with a clean, there's plenty of threads here how to do this as well.
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Probably run some injector cleaner though it as well if you haven't done it for a while.
    and 3 Dangerous non ABS VN's
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    what year is ur car?
    vs calais
    Dec 2008
    Default 1996
    Quote Originally Posted by ephect View Post
    october 96...
    ive cleaned maf
    ran injector cleaner,
    done a full service
    how do you test o2 sensors?
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by admir87 View Post
    october 96...
    ive cleaned maf
    done a full service
    Re-do the error code test....
    vs calais
    Dec 2008
    Default ....
    Quote Originally Posted by 88GreenVN View Post
    will do it tommorow morning again but ive had nothing and i checked a week ago...
    i havent had the engine light pop up ever
    The1's Avatar
    Jan 2005
    Toowoomba QLD
    Theres two wires on the ecu D15 LH Sensor D13 RH Sensor you can hook a multimeter up, when the engines fully warmed up tap the throttle and it should go up and down from 0.1v to 0.9volt, 0.1v lean 0.9v rich. If it's sitting in one spot the sensors stuffed or not warmed up.
    To see it properly in realtime you need a scantool, but the multimeter lets you know it's not totaly dead.
    Sometimes the sensors might not log an error code but are slow or not working right.
    VP BT1 & BLOWN STATESMAN
    Oct 2005
    That sounds about right for city driving
    NEVER LATE IN A 355ci
  15. #15
    Kurtp's Avatar
    Kurtp is offline VR Buicks > You ;)
    VR Series 2 V6 Sedan
    Aug 2009
    Pakkey VIC
    16.5? how does that sound about right, i drive pretty hard and i have a buick and use about 12. And i thought that was shit!
  16. #16
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    june 96 was the first of the series 2, i was thinking possibly an O2 earthing issue which may also contribute to ur consumption, but that was a major issue with the series 1, might be something to consider though
  17. #17
    88GreenVN's Avatar
    Jun 2006
    You could try a different ECU just in case it's that. If all the sensors are new and working then the ECU may be sus and not processing the sensor data properly.
  18. #18
    vs calais
    Dec 2008
    Default oxygen sensor
    hi mate, ive read your thread on the earthing issues..
    so this mostly applies to pre june 96 vs models?
    i do have the 4 wire sensors but yes it is a series 2 oct 96
  19. #19
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    it was a known issue with the series 1, but im not 100% sure if it was fixed in series 2 models.
    the way i look at it is; it doesnt cost anything to do and at least you can rule out that whilst trying to diagnose/eliminate possible causes.
  20. #20
    94 VR BERLINA
    Feb 2009
    yer i had the same problem i changed the oxygen sensor and my fuel went form 13.8 per 100km to 17.8 per 100km's i fixed this problem by cleaning the throttle body changed the fuel pump and filter and get the car electronically tuned and now the car runs 12.8 in city driving and 10.2 on hwy .
  21. #21
    VS S Pack
    Sep 2009
    What temp should the dash gauge show for normal driving as mine barly gets off the first marker showing cold, as I have only owned the car a short time not sure if this is normal or some clown has removed the thermostat on it as it will get to half on the gauge if left idling for extended period or under continued load
  22. #22
    Wombles's Avatar
    Wombles is offline Cars cost too much.
    1995 VS Acclaim
    Oct 2009
    Hmm. I should test this on mine as it's a pre 96 model. :S
    For the thread creator, just make sure the air filter is clean, the fuel filter has under 50,000 k's on it and clean the throttle body out.
    http://forums.justcommodores.com.au/...e-acclaim.html
    My Commy
    Quote Originally Posted by danja View Post
    GM: Has millions of dollars and highly trained engineers.
    Some guy in his backyard: Has a hole saw.
    Discuss.
  23. #23
    calais_cruzin's Avatar
    calais_cruzin is offline Calais_Rattling....
    92 VP Calais 3.8
    May 2006
    Gold Coast
    Quote Originally Posted by Trikky View Post
    Last owner could have removed the Thermostat, or it could be seized open.
    Not hard to change, 30bucks around for new part.
    Ur temp should sit at the 1/4 mark at running temp.
    ________________________________________
  24. #24
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Half on the gauge is pretty normal for a VS.
    How is your air filter?
    Visit my Facebook page
  25. #25
    vs calais
    Dec 2008
    Default replyy
    Quote Originally Posted by Wombles View Post
    ive done a service on it a few kms ago, changed fuel filter and air filter and cleaned maf cleaned inlet manifold and throttle body
    ive done pretty much all you can when it comes to servicing besides changing injectors
  1. L.P.G and oxygen sensors
    By mattyr82 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-04-2008, 09:12 PM
  2. oxygen sensors
    By mahooody in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-11-2006, 09:32 PM
  3. Oxygen Sensors
    By wetwork65 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 23-06-2006, 10:16 PM
  4. Oxygen Sensors... a few questions....
    By andy05 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-04-2006, 09:40 PM
  5. Oxygen Sensors VS V6
    By Harvs82 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-03-2006, 06:25 PM
