Results 1 to 8 of 8
Thread: ve gts rim fitment
    brockee's Avatar
    brockee is offline (HOUSE OF POWER)
    VX S2 SENATOR SIG CAMMD A4
    Aug 2009
    mandurah> wa
    Default ve gts rim fitment
    hey all just afta some info for a mate he wants to put some ve gts rims on his vr will they fit ...?they are 20x8z not sure off tyre size yet or offset they are machined for pre ve!!!!!
    Vee-ard's Avatar
    Vee-ard is offline QuickVR95II 2010 Survivor
    Foam Tuned VR 5.0l Ute
    5 Miles 2 Go Champion!
    Jun 2009
    Bayswater, WA.
    no, VE rims will not fit a VR without modifying the car
    The hall of fame:
    Quote Originally Posted by lindsay.VS.Wagon. View Post
    ....a mini spool creates greater airflow to the engine which means more oxygen into the engine which adds greater combustion which adds an all around performance upgrade.
    Quote Originally Posted by edals View Post
    Also found running your lights all the time looses 100kms to a tank also.
    ಠ_ಠ
    05 VZ R8 Clubsport
    Oct 2009
    Melbourne VIC
    Yeah the VE ones wont fit but there are VE rims made just to fit the early models seen them on ebay
    brockee's Avatar
    Aug 2009
    mandurah> wa
    Dan VS 231's Avatar
    Dan VS 231 is offline Ell Sixty Seven
    VY Calais L67
    Jun 2008
    Perth W.A.
    From what Ive been told the hub is different on the VE and the wheels need to be machined out by about 3mm to clear the earlier hubs. If they are copies they should be made with this in mind and will fit anything from VL (I think?) onwards.
    VR Executive S2 3.8L
    Mar 2011
    Burpengary, Brisbane
    Yeah they need 3MM machining (should only be 20$ish per wheel at a wheel shop) to fit a VR / VS
    LOOKING FOR VS / VR LEATHER SEATS AND WOODGRAIN CENTER CONSOLE PM OR EMAIL ME!!!!!!
    vn commodore s2 BT1
    Mar 2010
    Mar 2011
    im going buy what i saw on a eBay item (VE GTS rims) saying the jsut need to be machined 3mm to fit the hub (i have 2x of the 20" VE GTS rims im thinking about putting on the front of my VR
  1. towball fitment?
    By s_t_r_e_t_c_h in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-12-2008, 09:15 PM
  2. extractor fitment
    By SSbeast in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-08-2008, 01:34 AM
  3. spring fitment
    By greenvs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-04-2007, 08:28 PM
  4. LPG fitment to VP V6 & ECU changes
    By mutley770 in forum V6 Development And Modification
    Last Post: 01-09-2006, 09:16 PM
  5. NOS fitment
    By Barcode in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 23-08-2005, 09:42 AM
