Results 1 to 7 of 7
Thread: t5 speedo sensor help
    VS SS MANUAL
    Aug 2009
    BRISBANE
    Question t5 speedo sensor help
    so my speedo stopped working recently and i have traced the problem back to the speedo sensor, there are 3 wires coming out of it, 2 of them are still connected (just) but the 3rd has broken off.
    i have removed the sensor in an attempt to reconnect the wires back on but i cant seem to pull the top off the sensor, so my question is...
    does the top of the sensor come off or once the wires break do i have to replace the whole vss?
    any suggestions would help.
    cheers
    VS SS MANUAL
    Aug 2009
    BRISBANE
    here is a pic..
    as you can see its broken off right and the sensor.
    [IMG][/IMG]
    vx gen111 wagon
    Jul 2009
    perth
    hey dirty sanchez mine did the same dig into the plastic seal carefully until you get just enough of the brocken wire to put a terminal onto it. should be able to do this without going right through the seal but if you do carefully seal it back up with sikaflex
    VS SS MANUAL
    Aug 2009
    BRISBANE
    VS SS MANUAL
    Aug 2009
    BRISBANE
    ok so ive made some progress, managed to get the top off the sensor to expose some more wiring, but as you can see there is only a tiny bit left to play with.
    i cant beleive they design them this way, anyway im going to attempt to solder the wires back on and see how that goes.
    car
    Jul 2006
    greensy, melb
    just go get one from the wreckers otherwise they are about $220 last time i asked at holden
    "A life lived in fear is a life half lived"
    VS SS MANUAL
    Aug 2009
    BRISBANE
    cheers, looks like im gonna have to..
LinkBacks (?)
  1. Speedo signal wire for speedo corrector
    By Thomas1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-12-2009, 08:14 AM
  2. VH heat sensor and petrol sensor!
    By budgieVH in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 11-05-2009, 10:58 PM
  3. speedo sensor wiring.
    By bendez in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-10-2008, 10:49 AM
  4. My Speedo is 10kmh out. Speed sensor?
    By L67 Calais in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-09-2008, 08:28 PM
  5. Need some help!!!! abt speedo sensor on Vr (auto to manual conversion)
    By holdenrocks in forum Electrical Wiring / Questions
    Last Post: 29-03-2008, 08:20 AM
