Results 1 to 4 of 4
Thread: can a vl diff go fit straight into a vs commodore
    vs commodore
    Nov 2009
    Default can a vl diff go fit straight into a vs commodore
    hi i got a vs commodore with a solid diff and i got 19's 245 on it and it's srubing pretty bad. I already have a adjutable panhard rod and it's been lowerd 3in on the back any ideas or can i put a vl turbo diff in it for clearence.
    thanks steve
    vs commodore
    Oct 2009
    Tamworth NSW
    I once fitted a lsd out of a VN into a VS and it was narrower,it looked stupid with chaser rims fitted .Someone suggested the diff might have came from a VL to begin with,but Im not sure,you couldn't notice it on the VN ,It looked normal width, so maybe they are wider on the VR/VS and you can just use a vn one .I know they bolt up ok.Everything is the same.
    Mar 2009
    A VL diff will fit but is narrower than your VS one by approx 40mm... You could go from having rubbing issues on the outer lip of the guard to having them rub on the inner guard if you fit a VL diff.
    I have got 245/19's on mine and they dont rub at all.. mine is on pedders ultra low and i have rolled the guards to clear.
    If you dont have your guards rolled get them done and it should fix your problem (thats if its rubbing on the outer lip of the guard)
    vs commodore
    Nov 2009
    yer i think got sommething to do with the offset i got gmax eagles with a inch and abit of dish and i think that wat causing the srubing problems
  1. commodore diff ratio
    By ravenvtss in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-11-2010, 12:47 PM
  2. Will a Vy Diff be a straight swap into a Vt
    By damnet in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-05-2009, 08:48 PM
  3. VS commodore diff problem
    By les82 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-03-2007, 09:10 PM
  4. Does your standard Commodore V6 do ford straight ^??
    By Hairy Eater in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-12-2005, 11:25 PM
  5. Does your standard Commodore V6 do ford's straight 6??
    Last Post: 21-12-2005, 06:32 PM
