Results 1 to 2 of 2
Thread: engine swap from vs ecotec to vr s/wagon(non ecotec)
    vr commodore
    Dec 2009
    Smile engine swap from vs ecotec to vr s/wagon(non ecotec)
    im fitting an ecotec v6 from a vs commodore to a vr commodore s/wag whitch is not ecotec. how do i go with the lume on the ecotec engine and will the engine pipes on the ecotec engine bolt up to the standard exhaust system.also do i have to change anything to make it run.and also wiring issue at the battery area where a six pin plug joins up to a five pin plug.
    vr berlina v6
    May 2010
    Hi mate, I am doing the same engine swap, I have done the wiring changes but my motor will not start I have spark and fuel pressure but still no start, if I get some where with it I will let you know, and exhaust system dose fit.
  1. Buick to Ecotec Swap
    By Weekend Warrior in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-05-2009, 06:48 PM
  2. Swap WA: 96 Vs Ecotec for 308 1970's 1 tonner
    By betts in forum Swap / Wanted to Buy / Trade
    Last Post: 07-07-2008, 09:20 PM
  3. ecotec to ls1 swap, what problems will i have?
    By fluxxx in forum General Discussion
    Last Post: 04-05-2007, 01:21 PM
  4. N/a to S/c ecotec engine swap
    By DaBakes in forum V6 Development And Modification
    Last Post: 15-04-2007, 08:22 AM
  5. ECOTEC: Whats the diff between VS S1 & VS S11 & VT V6??? Engine swap
    By holden#1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-01-2006, 07:45 PM
