Results 1 to 8 of 8
Thread: black smoke on high revs?
    Manual VS
    Nov 2009
    SA - South
    Default black smoke on high revs?
    hey all,
    i drive a manual vs, with pacemaker extractors, full lukey 2.5" exhaust.
    a mate of mine noticed a fairly big puff of black smoke coming out my exhaust when i changed from 2nd into 3rd. at about 4,000rpm.
    could it be my vt injectors playing up?
    my car is running on standard 91 petrol at the moment (last tank ran on 98, and tank before ran on 95) all from the same bp servo. i wanna see how differently it runs.
    my car also ticks when running, got told thats just the injectors as alot of ecotecs do the same.
    thanks!
    note: i normally drive like a grandma, and change at around 2,000rpm. may my injectors just be clogged up or something...?
    vs commodore
    Oct 2009
    Tamworth NSW
    It depends if the ticking is coming from the injectors or from inside the engine.
    Troy5L's Avatar
    Troy5L is offline building a lemon
    Blown VS Clubsport, Hektic Bravo ute
    Jun 2005
    Mornington peninsula
    yeh the ticking is just the injectors, alot of cars do that so dont worry about that.. the black smoke might be because u are running 2 rich high in the revs...it can be sorted out in the tune, it migh work but its worth givin a try, so if u think it could help giv greenfoam a pm
    Vortech V1 supercharger : 10psi : Intercooled : 3.89 Mini-spool : VT Big Brake conversion : Shift kitted auto : B&M Shifter
    My VS CLUBBY!
    237.2RWKW - 318.1HP - 926.4 NM
    Quote Originally Posted by ari666 View Post
    "putting additives in your oil is like putting things up your bum.... to some people its the best thing in the world, but to me its the most horrid thing i coud possibly imagine"
    Jesterarts's Avatar
    Jesterarts is offline Your freedom ends where mine begins
    2005 HSV Z R8 Manual
    Nov 2005
    Mornington, VIC
    If the black smoke started after the exhaust was put on, I'd say the O2 sensor has been fouled or broken.
    That would be my guess.
    Paiste402's Avatar
    Paiste402 is offline My workin on the car face
    1992 EB Fairmont Ghia
    Oct 2007
    Normanville SA
    Quote Originally Posted by Troy5L View Post
    how can you say that when you havent heard the car?! be careful when you give advice.
    Quote Originally Posted by <TVR-161> View Post
    yeah vts are becoming the new vn here, seing plenty with rear stockies, front chromies towing invisible caravans.
    Manual VS
    Nov 2009
    SA - South
    my mechanic did say that its the injectors,
    would getting new ones fix it - or will they most likely tick aswell?
    yeh your probably right, it could be the sensors and that..
    the guy before me tried 3 different exhaust setups coz the other ones blew a bit of smoke and that.
    but when i got the car no smoke what so ever with max revs in neutral. (8months ago)
    Vee-ard's Avatar
    Vee-ard is offline QuickVR95II 2010 Survivor
    Foam Tuned VR 5.0l Ute
    5 Miles 2 Go Champion!
    Jun 2009
    Bayswater, WA.
    If it's been running black smoke for ages, its running too rich.
    The hall of fame:
    Quote Originally Posted by lindsay.VS.Wagon. View Post
    ....a mini spool creates greater airflow to the engine which means more oxygen into the engine which adds greater combustion which adds an all around performance upgrade.
    Quote Originally Posted by edals View Post
    Also found running your lights all the time looses 100kms to a tank also.
    ಠ_ಠ
    vs commodore
    Oct 2009
    Tamworth NSW
    The exhaust system is not going to cause the smoke,you could fit 100 different systems and it wont stop the smoke.The smoke is produced by the engine, not the exhaust pipe itself.As V said,the engine is running rich.Try checking for error codes,see if anything shows up.Checking error codes VR/VS (Revised)
  1. Revs too high
    By theperthvan in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-01-2009, 02:48 AM
  2. revs too high!
    By kwik6 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-02-2006, 10:58 AM
  3. vk v8 cuts out high revs???????
    By mitchplz520 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 01-12-2005, 10:07 AM
  4. REVS. how high?
    By statesman_vs_s1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-05-2005, 10:34 PM
  5. High revs for no reason
    By DJ Majah in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-11-2004, 01:12 AM
