Results 1 to 12 of 12
Thread: Problem with vs commodore
    VS Commodore
    Jan 2010
    Angry Problem with vs commodore
    Can some one please help me why overflow bubbels... i just have replaced thermostat, flushed the radiator done the bleed screw. There is no sign of milk under the oil cap. Car looses water a little bit but it doesnt leak on the ground what does it go??? There is no sign of water coming out of the water pump.... and the carpet is not wet inside of the car....???....
    but i still have to check if my thermo fans are working but the car doesnt get hot enough for them to work.... thank u ... iif not i will burn the bloody thing!!!
    GetToDaChopa is offline Blues Brother # 2
    The Blues Mobile
    Dec 2008
    Western Sydney
    VS Commodore
    Jan 2010
    VS Commodore
    Jan 2010
    I dont think it is.... it sounds like a boiling kettle under the bonet ....
    hakhawk's Avatar
    hakhawk is offline smooth moderator
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    VS Commodore
    Jan 2010
    vs commodore
    Oct 2009
    Tamworth NSW
    It sounds like a blown or leaking head gasket.And you dont always get coolant mixed with oil when these blow or leak.(which means no milky stuff under the oil cap).Id get the cooling system pressure tested.And do a compression test on the engine.These are cheap to get done and will show whats up.(if anything is)
    VS_Pete_1's Avatar
    VS_Pete_1 is offline Donating Member
    VE II SV6 MY12 Sportwagon
    Dec 2007
    Brett jjj is on the ball. Get the tests done as he has advised mate.
    "Success is the ability to go from one failure to another with no loss of enthusiasm" Sir Winston Churchill.
    My VS II Berlina Wagon
    MY12 II SV6 Sportwagon
    VS Commodore
    Jan 2010
    [QUOTE=Brett_jjj;1410876]It sounds like a blown or leaking head gasket.And you dont always get coolant mixed with oil when these blow or leak.(which means no milky stuff under the oil cap).Id get the cooling system pressure tested.And do a compression test on the engine.These are cheap to get done and will show whats up.(if anything is)[/QUOTE
    Thank u for that i will see how i go on monday ......
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    When you replaced the coolant - did you have the heater running when bleeding the coolant system?
    and 3 Dangerous non ABS VN's
    vs commodore
    Oct 2009
    Tamworth NSW
    Also have you checked your radiator cap,these caps use a double seal so the radiator can suck coolant back through from the overflow tank once the engine cools down.Make sure its the right cap and check the seals for aging,cracking etc.Or better yet,replace it.If it shows up to be fine,get the tests done I mentioned before.
    VS Commodore
    Jan 2010
    We bought new radiator cap today… and so far so good…. But the temperature gauge is really strange or am I just paranoid…. It goes over half when we drive it … I think it could be time to sell the car…. Sick and tired off fixing the commodores  ……… see how I go for few days… and we did do the bleed screw with the heaters on … who bloody knows…. Sometimes I wish I was a mechanic
LinkBacks (?)
  1. commodore problem
    By iceknight in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-08-2009, 04:08 PM
  2. Ignition problem with VR Commodore
    By hopping-mad in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-12-2008, 12:01 AM
  3. 95 VS Exec Commodore problem
    By poxpox in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-01-2008, 09:33 PM
  4. VS commodore diff problem
    By les82 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-03-2007, 09:10 PM
  5. Vh Commodore- Fan Problem Plz help
    By pinguino in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 30-04-2004, 06:09 PM
