was wondering why might my temperature gauge is only showing the needle on the bottom 2 lines has anyone got anyideas what the problem might be
ah k kool might change it thankz
You might try replacing the cooling system thermostat,it regulates the engine temp.Its spring can become weak over time and open too early or it can seize open,causing the engine to run to cold all the time.
