Results 1 to 10 of 10
Thread: VR "thudding" under load at speed
    VR commodore executive
    Dec 2009
    Default VR "thudding" under load at speed
    My VR "thuds" (similar to hitting a series of centre road reflectors with the tires) when I accelerate between 90 and 100 kph. I don't know if it's "missing" and whether that is fuel injection or spark problems but it is a worry. What migh it be? how do I find out? any answers?
    vq stato 5l 5 speed
    Jun 2009
    South australia. The defect state
    VS SS V8
    Oct 2009
    Townsville, Qld
    check for error codes first, see if anything comes up
    Checking error codes VR/VS (Revised)
    if nothing shows up on error codes, probably have to start usual diagnosis...
    leads... plugs... coil packs... dfi
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Could be the TCC (torque converter clutch) slipping or not dis-engaging properly although first I'd check as per VSPantha's post.
    5 speed VR's Avatar
    5 speed VR is offline Green Machine
    Vr V6 Exc 5 spd
    Apr 2006
    Sunny Coast QLD
    i had this problem, its the torque converter (probably got a crack in it or something and might be throwing loose bits of metal through your gearbox). Get it fixed asap or you will have the problem i had after leaving it for a year and have the car start to bunny hop :P
    When i grow up... i want to be young again
    08 Omega
    Apr 2009
    i had a problem like this also, it was one of my coil packs, replaced it and it runs smoothly now. hope that helps.
    Dec 2009
    to KOMNHOR - vehicle has 250000km but is running very smoothly apart from this problem.
    5 speed VR's Avatar
    Vr V6 Exc 5 spd
    Apr 2006
    Sunny Coast QLD
    if it doesnt do it under 80km/h and only 90km/h-100km/h when ya put ya foot down to overtake does it kick back a gear or just start thudding/shuddering?
    VS 3.8l Exec
    May 2006
    Ya mums house!!!
    I'll agree with the coil pack and DFI module, I had this exact same issue with my car, I changed plugs, leads, fuel filter etc and in the end the coil packs were stuffed...
    I would suggest doing those... although it's expensive... so get some second hand ones from a wrecker and see how you go!
    vq stato 5l 5 speed
    Jun 2009
    old wagon had this prob. maybe a tailshaft on the way out thats wat mine was i rekon from memory anyhow. next time u drive as u accelerate between 20 and 60 try to feel a vibration noise
  1. Do "police pack" cars have a standard v6 or the "high output" one?
    By Gibson_83 in forum VE Holden Commodore (2006 - ?)
    Last Post: 31-08-2011, 05:42 AM
  2. [308] vn heads "sydney speed"
    By fat084 in forum V8 Development and Modification
    Last Post: 22-08-2009, 10:27 PM
  3. Replies: 13
    Last Post: 26-03-2009, 05:34 PM
  4. VR Buick 5 Speed .. "That darn noise !" help
    By mitchyp in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-05-2008, 07:56 PM
