hey all, i have started the process of installing power windows in my wagon, except i have come across the problem of not having the bottom terminal in fuse slot #5 nor the relay for the power windows.
the car also does not have the plugs for the front switches to plug into, but i have bought these from the wreckers and need to wire these up (im a little confused about where some of the wires are supposed to go)
i have searched and read the forums on here and other sites, but i cant seem to find the answer to my question.
with this terminal missing, how easy is it to wire the bottom terminal up, and how easy is it to wire the relay up? i have all the regulators, door looms, switches etc, its just this last bit of wiring that is confusing the hell out of me.
i realise i may have got a bit ahead of myself and thought it was going to be easy, without understanding much about wiring, but if anyone could shed some light on this i would appreciate it heaps.
if u need pics to clarify what im talkin about let me kno and ill get some and post em up.
thanks, Russ
All the looms and switchs should be plug n play as such. When you get the door looms and motors and stuff you should also get the window dash loom if not already in the car.
Consol switches plug into the main window dash loom - Dash loom goes to all 4 window looms and the window control module. (is for the VN)
and 3 Dangerous non ABS VN's
Hey just a quick power window question. Will door looms and motors out of a vq s2 work in a 95 model vs exec?
