I need pictures of the hoses on the left side of the engine on an LPG VS V6. Mine has had the LPG setup removed and a new (incorrect?) radiator fitted. The pipes are a confusing mess and the heater is perminently on and draining into the plastic tank up by the strut tower.
So please, Pics anyone?
Do you want a pix of a non-lpg VS or one with it......you says the lpg is removed so wouldn't you need a non-lpg VS? Also by left side do you mean pass or drivers side?
Drivers side, sorry. And An LPG VS. This one seems to have a similar radiator setup to the VN V6, but is confusing as there doesnt appear to be any kind of overflow system
an overflow bottle usually comes from below the radiator cap as the spring on the radiator caps goes up and down to suck in or out of the bottle.
the pipes of the left hand side of the engine looking from the front are usually the heater tap from the firewall to the engine.
Yes, however this car is a bit odd. Its an ex-taxi that has had its lpg system removed, and it doesnt have any kind of pressure release radiator cap or a heater tap. It has a plastic top tank up by the drivers strut tower with a plastic cap, and no overflow bottle. will post pics tomorrow
