Results 1 to 8 of 8
Thread: help error codes 66 67 81 82????????????
    zoe
    zoe is offline
    vr executive v6
    Jan 2010
    Angry help error codes 66 67 81 82????????????
    my vr keeps getting error code 66 67 81 82 first took to the mechanic fixed solenoid, second time wiring loom now its blowing the trans fuse every time i put a new one in HELP
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Maybe the loom has an internal short or is not the correct loom for the VR - VR has 13 pins, VS has 14 from memory.
    vs commodore
    Oct 2009
    Tamworth NSW
    All you can do is check the trans wiring for bare or chaffed wires,if you find nothing,I'd be seeing a auto trans specialist.I looked up these errors,they all point to auto trans problems.
    zoe
    zoe is offline
    vr executive v6
    Jan 2010
    iv'e just taken it back to the mechanic who did the loom, hopefully its just a faulty wire, it's just that last time i was there it cost me $500, and nothing appears to be fixed
    Mar 2009
    with that amount of codes coming up its defo an electrical fault.. more than likely a trapped or broken wire, or the loom has come unplugged on top of the gearbox. That will of happened when your mechanic was working on it last time.. he shouldnt be charging you to fix it this time if thats the case.
    and certainly not $500!!!!!!
    zoe
    zoe is offline
    vr executive v6
    Jan 2010
    all fixed some wire needed repairing in the bell housing or something, only $110 this time thank god
    vs commodore
    Oct 2009
    Tamworth NSW
    That is more than likely the mechanics fault ,especially since hes already"fixed" the wiring once already,You should have made them fix it for free,because they have either caused it last time you were there or didnt fix it the first time.
    Mar 2009
    i bet he didnt fix it correct in the 1st place and has charged you for the pleasure...!
  1. ABS Error Codes
    By kopper69 in forum Holden Commodore How-To's
    Last Post: 19-12-2011, 08:28 PM
  2. VY trouble codes/error codes. NEED HELP!!
    By GILLO in forum VY Holden Commodore (2002 - 2004)
    Last Post: 16-03-2009, 04:04 PM
  3. error codes 32 and 76
    By zoran119 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-12-2008, 08:10 PM
  4. cant get error codes out of ECU
    By stocky in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-12-2008, 02:17 PM
  5. ABS Error Codes
    By nick88 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-11-2007, 04:20 PM
