Results 1 to 6 of 6
Thread: Power steering problem
    some_guy's Avatar
    some_guy is offline Donating Member
    VR SII Exec.
    Apr 2009
    brisvagus
    Default Power steering problem
    About a month back my power steering started to fail out of the blue and eventually broke down. I took it too a power steering mechanic. since then he has replaced
    6 x powersteering pumps
    2 x power steering racks
    2 x sets of pressure hose
    The last time was a complete replacement of the whole system, after this i decided for some whacked reason, to turn off my aircon. ( it had been on every other time the power steering failed ) Since switching the aironditioning off the power steering has worked fine.
    Does anybody know if a fault in the aircon compressor could cause the power steering to snap 6 psp mainshafts?
    p.s The mechanic at the shop said they tested all my bearings the ran on the drive belt and they all worked perfectly
    97 WRX AWD
    Tein Coilovers + EDFC Dampener Control - Whiteline heavy duty Rear sway bar - Whiteline Droplinks front and rear
    Turbosmart dual stage boost controller
    IHI VF34 Turbo - XForce 3inch TBE - Oversized TMIC - Unichip PiggyBack ECU
    PPG Straight cut 1st & 2nd, Slight helical 3rd & 4th and standard fifth - HD Clutch - custom braided clutch line
    02 wrx 4pot front calipers - DBA500 two peice slotted rotors - Steel braided Lines
    BP98 safe tune @ 171.8awkw
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    thats nasty. so i guess you replace the AC pump next. somehow the AC pump is creating a LOT of extra load through the serpentine belt that is stuffing up the PS pump. the PS pump runs a white metal bearing system much like the mains/big end bearings in the engine that is oil fed (or in this case PS fluid) from the pump itself.
    Body by Holden, Soul by Brock
    the Legend will live forever
    vs commodore
    Oct 2009
    Tamworth NSW
    Ive seen a faulty AC compressor smash the alternator bearings on a VN.Three alternators later we found the AC compressor occasionally locking up and when it did it would just smash the internals of the alternator.I think this is also why Holden put an idler pulley on later models before and after the AC comp pulley.Cheaper and easier to replace an idler pulley instead of alternators.
    some_guy's Avatar
    VR SII Exec.
    Apr 2009
    brisvagus
    thanks for that, my next move will be to replace the ac compressor.
    97 WRX AWD
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    I wouldn't replace the A/C compressor yet - the reason it may be seizing could be external - like a blocked TX valve or a blocked drier or it may have too much gas etc.....if it is indeed the compressor causing the problem which to me just doesn't add up.
    Were the pumps and racks all reco or new?....
    If the A/C comp was to seize, the belt would scream and smoke and there would be no way you would not notice it.
    vs commodore
    Oct 2009
    Tamworth NSW
    A bloke I knew who worked at holden a few years back told me about how there was some service notice about Holden having some problems with early VN's and the AC compressor and alternator,the compressor would lock up,but only for like a second or two,enough to do damage to the Alternator.After hearing this, and as I said before, after 3 alternators,we replaced the AC compressor and it didnt happen again.Then later models had the idler pulleys either side of the AC compressor pulley.I thought that must be why holden had fitted the idler pulleys to the later models.And Im not saying its the same problem,his is a VS,this was VN ,it could be a blocked AC system etc,but the hi/lo pressure switches should cut the compressor off in such a case.You wouldnt think the serpentine belt would snap the power steering pump shaft either,Like what has been happening with "some guy",you would think it would just lock up.Thats why I posted about the VN AC compressor problem I had before.
  1. VZ SS Power Steering problem
    By loudvtss in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 29-05-2012, 07:28 PM
  2. Power Steering Problem
    By Trevor 062 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-12-2010, 02:18 PM
  3. problem with power steering
    By bagmup in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-11-2006, 08:10 PM
  4. power steering problem
    By BUSTA in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-08-2006, 10:45 PM
  5. power steering problem??
    By lilkel in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-06-2006, 07:04 AM
