Results 1 to 5 of 5
Thread: cruise control
    vs
    Jan 2010
    Angry cruise control
    i have put factory cruise control in my 98 vs ute and it dose not work i have to holden thay dont no ether
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    can you provide any more info, saying it doesn't work doesn't give us anything to work on with you. Does it power on? Does it go to activate and just not hold?
    The1's Avatar
    Jan 2005
    Toowoomba QLD
    i had a look through some of my files on my pc today and found the cruise control ones i had scanned
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    The1 - that's what I wished I had when I installed mine!
    MollyVS =
    But here is another link that also may help:
    How do I install genuine cruise control on a vs executive?
    94 vr 5sp, 04 vz wagon,82 vh efi wagon,88 vn 5sp
    Nov 2003
    northside brisbane
    You have to find out if the unit is geting powered from the stalk switch....if you push the on/off button on the stalk does the light come on the dash.....usually the first problem of install is that there is no provision on the install car's bcm for it to toggle...that is when you push the on/off button on the bcm supplies constant power to the small relay near the column to put 12v on the unit.
    This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain ......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
  1. Man conversion-cruise control, will the auto cruise control work on manual conversion
    By pjdm1980 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-08-2009, 12:25 PM
  2. Need help - Cruise control
    By Shelfish in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-04-2009, 05:47 PM
  3. Traction Control / Cruise control crapped out!!
    By DarkCrystal in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-02-2008, 06:37 PM
  4. Cruise Control and Climate Control?
    By Mr_mystikal in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-04-2006, 06:29 PM
  5. cruise control no control
    By foxinjox in forum Electrical Wiring / Questions
    Last Post: 16-11-2005, 01:32 PM
