Hey guys,
Just installed a couple of new speakers in the back of my VR, the speakers were fine but I noticed when I put my brake on about halfway kinda the rear speakers have a bit of crackle/distortion.
Anyone know what could be causing this? The connections seems to be on there strong so im not to sure.
are you using stock wiring for the speakers? if not maybe you wraped that lead around the brake light cord a few to many times lol
Im using the stock wiring, there was 2 plugs from the original speakers wiring (where the speakers plugged into) which I cut off and then used the wire instead of the connector and wrapped that wire around the speakers.
Took the speakers apart and put them all back together again it seems to have fixed itself. If it starts doing it agian ill post again but cheers anyway.
