Results 1 to 12 of 12
Thread: PS fluid running out all the time
    VS Executive S2
    Jun 2008
    Default PS fluid running out all the time
    I have to fill up my powersteering fluid often.
    It was once every 6 months or more. Today it's dry again and I filled it up 1 month ago.
    Is there a crack in the container or is it more terrible?
    Are containers easy to replace and how much for a new one?
    It's on a VS.
    MX83
    Jul 2008
    hills area, sydney
    Could be a leak anywhere in the system. Have a look under the car when you park it and see if you can see any leaks.
    JCCC NSW
    Quote Originally Posted by Troy711 View Post
    My mum dropped me off at work one day and she was doing 90 in a 60 zone. When I pointed this out to her she said 'shut up, if you don't like my driving you can get out and walk'.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    You mention the possibility of a crack in the container so I presume that is where it appears to be leaking from. I had a leak from the container which I thought was a crack but found it to be the hose where it connects - bought 2 new hoses and this fixed my problem. The hose goes hard which prevents it sealing.
    VYMAD's Avatar
    VYMAD is offline SILVERFOX
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    If it's leaking that much then you should easily be able to see where it's leaking from. If not, then either degrease the whole lot or at least give everything a good wipe over with a rag, go for a drive, then take your time and check the reservoir, hoses, hose clamps and the steering rack for signs of red fluid. Given that amount of fluid loss, I would say that you would see it on the ground underneath the car where you park.
    VS Commodore Ute
    Nov 2009
    the container is reknown for leaking on the join, look along were the 2 peices join each other, tighten all hoses etc
    VS Acclaim
    Jan 2010
    vr series 2 v6
    Oct 2009
    nsw
    ok whats probally happened, with power steering if u over fill it, it busts all the seals and you have to either get it resealed or get a new one, i had a spare and just recently happened as filling up the power steering fluid when i was drunk one morning for the mrs who had to go to work, it was overfilled i was half drunk half hung ova and said **** it, wont hurt havin too much than not enough, well not in this case
    Vs eco 3.8, extractors, 2.75" exhaust, roller rockers, cammed, bored out 20, t5 manual, rolling on king springs all way round with monroe gt shocks all way round, every door has a ding but looks can be very deceaving
    2005 VZ SV6
    Jun 2009
    Australian Crapital Territory
    According to my numerous calculations, it appears to me that you have a leak.
    Sorry, had to say it :P
    soop is offline Banned
    2003 SS Commodore Series II
    Nov 2008
    Smithton, Tasmania.
    vs commodore wagon
    Dec 2008
    Mate if its not any of the problems mentioned and if it making a whining noise while you turn the steering wheel its the pump itself.Thats what happened to mine.Hope that helps.
    VS Executive S2
    Jun 2008
    Thanks for all of your input.
    I looked for leaks and only found an oil leak from underneath.
    I took it to the mechanic and the whole thing needed to be overhauled which was pretty expensive, but now it's fixed.
    vr series 2 v6
    Oct 2009
    nsw
    Quote Originally Posted by theperthvan View Post
    yea that was seals, would of been better of going to a wreckers, oh well at least its done
  1. In need of a part time job (i work full time)
    By Niggadore in forum The Pub
    Last Post: 29-10-2009, 07:50 PM
  2. engine light on and stall time to time asap help
    By kevinwilly123 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-09-2009, 09:32 AM
  3. is this a good time to be running
    By p_schrapel in forum V6 Development And Modification
    Last Post: 04-01-2009, 10:51 PM
  4. VR Engine light stays on running running alittle rough
    By AJKoo1 in forum General Discussion
    Last Post: 07-09-2006, 01:08 AM
  5. Brake Fluid and Auto Trans Fluid.
    By Melchior3 in forum General
    Last Post: 20-02-2006, 11:49 AM
