Results 1 to 5 of 5
Thread: VS 5ltr Themo Fan issue
    95 VS 5ltr Statesman D/Fuel
    May 2005
    Default VS 5ltr Themo Fan issue
    OK what controls the thermo fan, my reason is it cuts in and out all the time BUT won't stay on when it counts, or how can I get this to come on as it should and stay on
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    By thermo fan I gather you mean the electric fan?....if so it will be turned on by the coolant temp sensor which tells the ECU which will power a relay - if it's cutting out when it shouldn't be then I'd check the relay first.
    Turning the A/C also should make the fan come on.
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    Depends also, are you talking bout the little tiny one on the front or have you done a thermo fan conversion and tossed the clutch fan. If so how did you set them up....Did you use an external trigger cct or get the memcal modified to run the fans?
    Reaper
    VH Commodore
    Jan 2010
    The fan on the front of the condensor is a condensor fan and is controlled by a pressure swith in the aircon line. When the condensor gets to hot it turns the fan on. Nothing to do with engine temp.
    Ian
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    Wrong. The ECM/PCM will turn on the fan under the following circumstances:
    - if the coolant temperature exceeds 110 C (runs until the coolant temp is below 105 C),
    - if it detects a coolant temperature sensor failure,
    - if the AC request signal is received and the vehicle speed is less than 64kph,
    - if field service mode is active - ignition on, engine stopped, and DLC diagnostic "test" enable terminal earthed
    In addition, as you point out, the engine cooling fan relay can also be energised by the AC pressure switch.
  1. VQ 5ltr Stalling Issue
    By HoZy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-11-2009, 01:51 PM
  2. Vn ss 1990 5ltr - possible head gasket issue, help me
    By geronamo2008 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-10-2009, 10:06 PM
  3. Themo Fan Not Working,, Cause any Problems??
    By nilprapai in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-11-2008, 08:52 PM
  4. Themo fan trouble
    By mickah in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-11-2008, 10:04 AM
  5. VS /V6 themo fan ????
    By BUSTER1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-08-2008, 08:44 AM
