Okay guys, i am still having trouble starting my car, firstly i attempted to fix the inhibitor, which seemed to help, cleaned up battery terminals etc. Though it still fails to start sometimes. I'm getting Code 31 in my logs, Code 31 - Theft Deterrent Signal Missing
Does this relate to the immobiliser? And hence be maybe causing the car to fail to start?
Cheers.
There is a post on this thread by Ozdj which gives the run down on checking what is wrong. See if it helps:
Code 31: Theft deterrent signal missing
Kurt man, i'm pretty sure its to do with the keyhead battery going flat. Which causes it not to send a signal which doesn't let the car start.
Got a spare key you can try?
