Results 1 to 3 of 3
Thread: Annoying error codes
    whitevrboi is offline Just another white vr.
    VR Executive S2
    Feb 2008
    Default Annoying error codes
    Hey everyone,
    Lately my vr has been running a little abnormally...it suddenly started slipping really badly from 1st to 2nd, and it doesnt want to shift up out of second, i find if i turn the car off then on again it fixes the problem but only for a little while. I checked the error codes and came up with:
    22: Throttle position sensor low voltage
    26: Mass air temp sensor-unstable voltage
    69: TCC (what is a TCC?) stuck on
    Any and all help would be greatly aprreciated as its starting to drive me up the wall...but responsiveness is good at speed
    Cheers Jack
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Maybe it is the TPS gone bad as this can affect the TCC (torque converter clutch - locks the TQ solid when cruising). Has the transmission been serviced lately? I'd also clear the codes (disconnect battery for 30 secs).
    VR Executive S2
    Feb 2008
    yea mate the tranny was serviced about 2months ago and there was a slight fluid leak when i got it back but i took it back to my mechanic n he fixed it up. I'll clear the codes n see what comes up hopefully it is only a sensor that needs replacing....thanks for the reply
  1. ABS Error Codes
    By kopper69 in forum Holden Commodore How-To's
    Last Post: 19-12-2011, 08:28 PM
  2. help error codes 66 67 81 82????????????
    By zoe in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-01-2010, 02:16 PM
  3. VY trouble codes/error codes. NEED HELP!!
    By GILLO in forum VY Holden Commodore (2002 - 2004)
    Last Post: 16-03-2009, 04:04 PM
  4. error codes 13 and 33
    By Pimpn1 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-01-2009, 08:02 PM
  5. ABS Error Codes
    By nick88 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-11-2007, 04:20 PM
