Results 1 to 15 of 15
Thread: Level 3 Cluster O/Speed Problem
    VXHBD6's Avatar
    VXHBD6 is offline Get Hozed!!!
    VR Executive
    Jail Escaper Champion!
    Nov 2009
    South Australia
    Default Level 3 Cluster O/Speed Problem
    Hey guys,
    Finally got around to testing all the level 3 functions, trip computer and everything works fine except for the Over Speed.
    I have tried setting it at a few different speeds and when I go over no light comes up or no chime (if its meant to chime)
    Anybody got some ideas as to what it could be? Does anybody which number globe it is on the cluster because i'll check that too.
    Check It Out
    My 93' VR Executive
    VXHBD6's Avatar
    VR Executive
    Nov 2009
    South Australia
    Edit: Seems to be fixed took the globe out, tested it with a battery and it worked so I put it back in the cluster and it works now. Weird.. musn't have been in properly.
    Check It Out
    My 93' VR Executive
    Fekason is offline Fekason
    MY11 VE Series II SV6 Manual
    Mar 2005
    Penrith NSW
    VXHBD6's Avatar
    VR Executive
    Nov 2009
    South Australia
    Alright i'll test the chime tomorrow.. but I think I read somewhere only certain clusters chime so mine might not?
    Check It Out
    My 93' VR Executive
    VS 3.8l Exec
    May 2006
    Ya mums house!!!
    All lvl 3 clusters chime, but for you to be sure you need one that works with an over speed chime...
    if your unsure, check the ribbon cables connecting the unit to the rest of the tacho...
    failing it dosn't work, grab another lvl cluster, pref a statesman as i know they chime!
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Quote Originally Posted by <VRCOMMY> View Post
    If it's not making the chime noise - it will have been removed from the cluster.
    and 3 Dangerous non ABS VN's
    VXHBD6's Avatar
    VR Executive
    Nov 2009
    South Australia
    Cheers Shane, if it has been removed is it easy to slap another one in? Or do you have to take the whole cluster apart?
    Check It Out
    My 93' VR Executive
    88GreenVN's Avatar
    Jun 2006
    It's cluster out, lens off and it plugs into the middle right at the front of the cluster. The chime is silver and like a wod of 5c bits about 1cm thick.
    Take about 10 mins to put one in. I have a box of them - people take them out after a few weeks of low fuel warnings and the like.
    VXHBD6's Avatar
    VR Executive
    Nov 2009
    South Australia
    Ah right, thanks man.
    Can you PM or email whatevers easier for you a picture of what they look like?
    Check It Out
    My 93' VR Executive
    88GreenVN's Avatar
    Jun 2006
    The chime is silver and round - about the size of a 5 cent bit. If you have the lens off - it's the only round silver thing on the cluster and is front & center inbetween the warning lamps along the bottom of the cluster.
    If it dont bite you when the lens comes off - you dont have one in the cluster
    VXHBD6's Avatar
    VR Executive
    Nov 2009
    South Australia
    Your right, the heat does give your brain a meltdown LOL!
    Whats the lens? The green backing stuff? Haha and what do you mean if it doesnt bite me
    Check It Out
    My 93' VR Executive
    88GreenVN's Avatar
    Jun 2006
    Cluster out on the bench - 3 screws hold the front cover (lens) onto the cluster case. Take this lens off and you will know if you have a chime or not.
    Bite you as in you will be looking right at it. (if it's in the cluster)
    VXHBD6's Avatar
    VR Executive
    Nov 2009
    South Australia
    Oh lmfao, the heats getting us both.
    Haha ill take a look tomorrow. Cheers lol
    Check It Out
    My 93' VR Executive
    VS '95
    Nov 2009
    My VS also chimes(both of them I have had) so yours should too. Defitnately something wrong with the one you got, maybe a faulty wiring or something?? Again my mate also has a VR and his also chimes..
    So yer, have fun fixing it.
  15. #15
    VXHBD6's Avatar
    VR Executive
    Nov 2009
    South Australia
    Haha my guess is someones just taken the chime out getting pissed off at speed alert or something (its a second hand l3 cluster) so i'll take a look tomorrow. If its there im in trouble, if its not i'll chuck one in
    Check It Out
    My 93' VR Executive
  1. vt level 3 cluster change problem vt s pak
    By dcjacko in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-04-2011, 08:59 PM
  2. vt level 3 cluster problem (help)
    Last Post: 06-10-2009, 08:00 PM
  3. level 3 cluster buzzer problem...
    By sniperknight in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-08-2009, 07:21 PM
  4. Dropping Level 3 Cluster into unready Level 2 ready VS
    By VS Omega in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-01-2009, 03:56 PM
  5. Problem Level 3 Cluster
    By ninjagarth in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-04-2008, 10:48 AM
