Results 1 to 3 of 3
Thread: Removing and Installing Fuel Pump (VS)
    2000 VS Ute 5 Speed
    Oct 2008
    Western NSW
    Default Removing and Installing Fuel Pump (VS)
    How do you remove and install a fuel pump on a VS?
    VR WAGON
    Oct 2009
    Same as VR ?... guess so!
    It is internal. Disconnnect the fuel line near the tail shaft, undo the six 7 ml nuts and slowly twist out the pump, it has angles to get to the bottom of the tank. undo the return line. DON'T SPLIT OR PULL TO HARD ON IT OR YOUR STUFFED. Connect the new pump to the return and reverse the procedure. Replace the filter as well. Undoing the pump at the tank is the only way to drain the petrol as well, as you undu the bolts.... fuel will start to come out, have a wide container to catch the fuel.
    VS_Pete_1's Avatar
    VS_Pete_1 is offline Donating Member
    VE II SV6 MY12 Sportwagon
    Dec 2007
    While you are there replace all the breather hoses some could be cracked I got them first to be on the safe side and a couple were brittle so done the lot. Be a shame if you have to drop tank again in a couple of months.
    "Success is the ability to go from one failure to another with no loss of enthusiasm" Sir Winston Churchill.
    My VS II Berlina Wagon
    MY12 II SV6 Sportwagon
LinkBacks (?)
  1. 18-12-2011, 12:03 AM
  1. installing VS oil pump?
    By lynnie in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-07-2011, 09:36 PM
  2. Trouble installing fuel pump
    By vps231 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-01-2010, 04:04 PM
  3. Removing & Installing P/S PUMP VN/VP
    By jetspin_vn in forum Holden Commodore How-To's
    Last Post: 03-10-2009, 12:42 PM
  4. removing fuel pump from vk calias v8
    By ported in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 08-08-2006, 07:51 PM
  5. removing and Installing help
    By Arth in forum Car Audio
    Last Post: 29-06-2005, 10:23 PM
