Results 1 to 12 of 12
Thread: VS v6 error code 65: LH oxy sensor rich
    vs S3 ute
    Nov 2009
    toowoomba QLD
    Default VS v6 error code 65: LH oxy sensor rich
    ok so got my first check engine warning today,
    just got back from 3000+km of driving up to northern qld and back with no errors, now i got one..
    error code 65 left hand oxygen sensor rich...
    the car certainly runs rich, the absolute best economy i could achieve through the trip is 620km / 55L fuel which is about 8.8l / 100km and that's running premium with a delcowizzid tune.
    before the trip i changed the oil and filter to nulon 10w30 high performance,
    installed new oxygen sensors, new fuel filter, ripped out the roll bars and tub liner, inspection plate and fuel tank to check for fuel leaks / perished lines, they were all good.
    since it's still using too much fuel any thoughts on what's wrong with it?
    i'm thinking change the coolant temp sensor next?
    still have a fuel smell in the cabin somedays which i can't for the life of me find a leak...
    the light came on while the car had been running for about 2 minutes and driving slowly up the road at about 40kph, i'm pretty gentle on it before it's warm.
    other than this problem so far no issues at all with reliability.
    VS 3.8l Exec
    May 2006
    Ya mums house!!!
    I had similar issues recently, I replaced an O2 sensor mid last year, and then 6 months later shat itself...
    reason being i believe is that I sprayed a fair amount of thottlebody cleaner in there, and replaced the IAC, and gave the throttle a really good clean! and sure enough all the junk stuffed the sensor...
    also I know a fuel smell can be evident when your o rings on your injectors are old and sh1t too...
    But to be honest sounds like you need to take it to a professional?
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    best bet is to hook it up to a laptop with a ALDL cable and see what the O2 sensors are reading. maybe the earthing issue the VS models have.
    did you use a genuine Holden O2 sensor? i've heard of generic sensors failing quickly before
    having a look at the injector O rings ins't a bad idea, could also cause a vac leak which could also make it run rich
    Body by Holden, Soul by Brock
    the Legend will live forever
    vs S3 ute
    Nov 2009
    toowoomba QLD
    i forgot to mention, i did the oxygen sensor earth fix before installing the new one's and if i remember correctly they're either bosch or AC delco.
    it's from this listing on ebay......
    OXYGEN SENSOR / O2 SENSOR - 4 WIRE HOLDEN & TOYOTA - eBay, Other Car Parts, Accessories, Car Parts, Accessories, Cars, Bikes, Boats. (end time 07-Jan-10 18:42:52 AEDST)
    they had the right plugs on them too just replace and plug in and zip tie the wires out of the way of extractors etc..
    who has a laptop with an ALDL cable?!
    vs_igby's Avatar
    vs_igby is offline vs_igby
    96 vs commodore
    Jan 2010
    there is also a known holden problem in the vs with the 4 wire o2 senor common earth which can cause all kinds off probs. There is a good thread on this topic in the how to's section. But if your not good with a soldering iron and understand basic car electrics i would take it to and auto elecs.
    here is the thread How To: Fix the VS V6 4 Wire O2 sensor earth problem – Known Holden Problem
    good luck...............
    vs commodore
    Oct 2009
    Tamworth NSW
    The 10w 30 oil you are using is to thin.It needs to be 20w 50 stuff at least.It might be burning a tiny amount of oil(which happens when oil is to thin) and its showing up as running rich .
    vs_igby's Avatar
    96 vs commodore
    Jan 2010
    sorry didnt see u already done the fix
    “I hate to advocate drugs, alcohol, violence, or insanity to anyone, but they've always worked for me.”
    ― Hunter S. Thompson
    VS L67 Statesman
    Oct 2006
    Melbourne, VIC
    Quote Originally Posted by immortality View Post
    What are they supposed to read? One of mine reads 0.7XXv and the other 0.9XXv (I think that's what they read, been a while since I did a log).
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    That fuel economy you quote for cruising of 8.8l/100km (or 32 mpg) is nothing to complain about in my opinion and is about what the car was good for when brand new. The code 65 can be set by many things from a plug lead bad to a blocked injector. If it only occurred after the trip it probably is not the sensor which you can test by simply swapping with the other side. The tune you have may not be designed for economy! I'd reset the codes as it may just be a one-off happening.
    And I agree with Brett on oil - 20w50 especially for cruising at high speeds - thinner oils cannot seal as well at higher temperatures that happen when high speed cruising.
    aceventura's Avatar
    aceventura is offline Doesn't drive like this
    Mazda 6
    Oct 2008
    SEQ
    Quote Originally Posted by Thomas1 View Post
    Supposed to fluctuate between 0.1V and 0.9V - At ~2500 rpm, the number of cross-counts (number of fluctuations per second) should be around 8, but preferably higher.
    VS executive
    Jun 2009
    id be stoked if i could get 600km from a tank! , delco tune here aswell.
    i usually do about 380 on the highway and have about a 3rd of a tank left which goes way too fast round the city.
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    im in oakey, just moving house this week but if you wanted a drive out i have laptop setup i can check your ecu and o2 sensors for you.
  1. Error code 24: Vehicle speed sensor (VSS).
    By Drift_Clown_VN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-01-2010, 05:06 PM
  2. oxygen sensor rich. (code 45)
    By VRoooom! in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-10-2009, 09:28 PM
  3. Error Code #15 and #16 - Coolant temperature sensor high voltage / unstable voltage
    By VSSECO in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-10-2009, 12:15 PM
  4. 1995 VRII Code 45: running rich on LPG
    By b_rocka in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-08-2008, 03:39 PM
  5. Error code 41, Crankshaft Sensor
    By PaRaDoX in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-09-2007, 06:23 PM
