Results 1 to 16 of 16
Thread: Cruise Control Stalk Wires
    VXHBD6's Avatar
    VXHBD6 is offline Get Hozed!!!
    VR Executive
    Jail Escaper Champion!
    Nov 2009
    South Australia
    Default Cruise Control Stalk Wires
    Hey,
    Basically the VR has 2 problems fuel gauge one which is been covered in another thread any my cruise control not working.
    As far as I know it came from the factory with cruise control but the guys that sold the car to us (who were original owners) did tell us cruise control hadn't been working for a while.
    I'm thinking of checking the brake switch tomorrow, but also testing out the cruise control stalk wires.
    I've no idea on how to use a multimeter though, I have to test for continuity I think? But how do I do that?
    Thanks.
    Check It Out
    My 93' VR Executive
    Wombles's Avatar
    Wombles is offline Cars cost too much.
    1995 VS Acclaim
    Oct 2009
    I have the same problem but I have ruled out the brake switch because mine got replaced not too long ago. It sometimes wouldnt make the tail lights go on.
    So im guessing its the wires in the stalk.
    http://forums.justcommodores.com.au/...e-acclaim.html
    My Commy
    Quote Originally Posted by danja View Post
    GM: Has millions of dollars and highly trained engineers.
    Some guy in his backyard: Has a hole saw.
    Discuss.
    VXHBD6's Avatar
    VR Executive
    Nov 2009
    South Australia
    Yeah mate, im planning on taking the stalk apart sometime this weak (maybe when the heat dies down a bit a bit first) and i'll let ya know how I go. How do you know if the brake switch isnt adjusted right for the cruise control?
    Because whenever I put my foot down my brake lights go on so yeah
    Just gotta try see if anywhere here can give me tips on how to test the stalk wires with multimeter.
    Check It Out
    My 93' VR Executive
    Wombles's Avatar
    1995 VS Acclaim
    Oct 2009
    I would not be sure. I'd just pull it apart and see if there's a broken wire.
    Heard the VR/VS's are netorious for wires breaking over the years. So that could be it.
    My Commy
    Discuss.
    VXHBD6's Avatar
    VR Executive
    Nov 2009
    South Australia
    Yeah but sometimes the breaks aren't actually visible, they can be inside the insulation which is when you need a multimeter so yeah.
    Basically I need to know where to put the connectors from the multimeter to the car. One obviously at the start of the stalk wires but wheres the other end of the stalk wire finish?
    Check It Out
    My 93' VR Executive
    Wombles's Avatar
    1995 VS Acclaim
    Oct 2009
    Maybe try putting the negative on the car body?
    My Commy
    Discuss.
    VXHBD6's Avatar
    VR Executive
    Nov 2009
    South Australia
    Yeah i'll see what some other people reckon first cause i'll have to go borrow a mates multimeter for the day
    Plus I thought for continuity both ends actually go to the wires, you dont ground anything?
    So yeah, anyone know for sure on how I go about testing the wires in the cruise control stalk?
    Thanks
    Check It Out
    My 93' VR Executive
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    VXHBD6's Avatar
    VR Executive
    Nov 2009
    South Australia
    Thanks The1, i'll give that a run and try go through those diagnostic instructions.
    Instead of having our car on stands for it can you just go out of town? Where theres no traffic?
    Check It Out
    My 93' VR Executive
    SweetWagon's Avatar
    SweetWagon is offline booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    Quote Originally Posted by <VRCOMMY> View Post
    The cruise control utilises its own brake switch and the switch for the brake lights, if either are adjusted incorrectly the cruise wont work, so make sure you check both switches.
    Power is measured in DECIBEL
    VXHBD6's Avatar
    VR Executive
    Nov 2009
    South Australia
    The1's Avatar
    Jan 2005
    Toowoomba QLD
    im pretty sure last time i tested mine i did it with the car off, you will here the step motor in the engine bay turning on.
    VXHBD6's Avatar
    VR Executive
    Nov 2009
    South Australia
    Ah right, cheers mate appreciated.
    Might do it outta town just to be safe but yeah. Process of elimination just gonna take some time. (and possibly some $$ )
    Check It Out
    My 93' VR Executive
    hsvpunk's Avatar
    hsvpunk is offline volunteer firefighter
    vy ss II M6
    Jan 2007
    Mornington, Vic
    in my stalk the RED wire was broken, i got a new stalk red wire was fiune and i now have CC again.
    dont worry, il start a ride thread soon.
  15. #15
    VS SS V8
    Oct 2009
    Townsville, Qld
    check the attached image for testing the CC switch... should help you determine if it's cactus or not.
    Attached Thumbnails Attached Thumbnails Cruise Control Stalk Wires-checking-switch-contacts.jpg
  16. #16
    VXHBD6's Avatar
    VR Executive
    Nov 2009
    South Australia
    hsvpunk: yeah the stalks seem pretty easy to replace so im not to fussed if its a broken stalk I just hope its nothing bad like the cruise module etc..
    VSPantha: Thanks heaps for that mate, having tea at the moment but once I finish i'll read that again in more detail and test it in the next couple of days!
    Check It Out
    My 93' VR Executive
  1. VY/VZ Cruise conttrol stalk in VT.
    By KillerCV8 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-01-2010, 06:47 PM
  2. [VIC] VS Cruise Module + Stalk
    By B3ND3R in forum Parts And Other Items For Sale
    Last Post: 28-06-2009, 12:19 PM
  3. inducator/cruise stalk
    By darren44 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-05-2009, 07:35 PM
  4. VT/VX Cruise Stalk
    By Indy_387 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-03-2007, 06:32 AM
  5. Indicator stalk w/ cruise control
    By Liddz in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-04-2005, 01:22 PM
