Hi guys found this product on ebay and would like to get some feedback and knowledge about this kind of upgrade. Reason for the upgrade is that I will be placing a bit more power into the vehicle shortly and I believe for engineering purposes a brake upgrade would be necessary. My front rotars are destroyed I thought it would be a good time to upgrade the front brakes anyway. From the link I have provided is this a simple bolt on product or is there anything else you can think of that I will need to spend money on.
http://cgi.ebay.com.au/Commodore-VR-...item2a0364c384
PS: My car is running a set of 19's, seems to have alot of space between the rim and the calopers so fitting these bigger brakes in shouldn't be a problem.
Any responses would be appreciated.
Thank you,
Your link doesn't work. What kind of an upgrade is it?
I just fixed the link.
Link works fine for me.
GSL RallySport (site sponsor) do the VE upgrade kits with all the bits and pieces as well.
VE Twin Piston Upgrade Package suit VB-VZ Commodore!!!
Thanks fella,
they look like the same kit ??
Hey bud,
Have you got this kit or did you mean they look the same ?
LOL, thanks mate.
you may want to consider doing the rears too...otherwise it may look a bit dicky with 322mm filling the front rims and tiny standards on the rear specially with 19's
I can get the rear slotted rotors in the same pattern so it won't look out of place. Smaller rears don't look that bad, not as bad as tiny fronts on large rims.
