I parked the car at the shops yesterday and realised I had overshot the end of the car park, so I reversed it back and there was a small pool of coolant on the ground. Pop the bonnet, the top radiator hose is coming off, so I try to jam it back on, but it pops off (and sprays me with coolant).
So, buy some water from Woolies, drive it back to my mates place, bleed it a couple of hours later. Then he spots a bit of coolant trickling under the top radiator hose mouth, and concludes it's probably a cracked radiator. It was probably time for a new one anyway, as I did a coolant flush about a month ago and the top hose mouth on the radiator had been half eaten away.
So, where has yours cracked?
I noticed my overflow bottle was empty one day... opened the radiator cap and it was down about 1 inch from the top. Found a leak bottom drivers side corner, half way up the drivers side and another near the tranny cooler outlet. There was also a bit of tranny fluid in the coolant.... ended up replacing the radiator.
My original radiator first died when the top hose neck blew off. Got the side tank replaced then the core sprang a leak about a year later.
yep mine was starting to crack at the top hose, was getting a coolant stain for a while so replaced it before it tottally cracked, new radiator was only $60, i did look at getting a alloy one but $500!! Next time maybe.
Mine cracked at the top hose outlet
core split in my vp and friends vs
If its got Wheels or Boobs its gonna cost ya money
