Results 1 to 12 of 12
Thread: Can vn parts go into a vr?(motor, trans, suspension)
    VT Calais International S/C
    Nov 2009
    Exclamation Can vn parts go into a vr?(motor, trans, suspension)
    Hey, I've got a VN commodore as a First car as i am only 16, it has a 3inch exhaust with Extractors, Lowered 2inches with King Springs, limited slip diff and the motor is a Reco and goes very fast together with the HSV ECU put in the car. This is all good and well but i just bought a VR with either a shot Trans or Engine. Its completely stock. So my question is can i put all the exhaust, springs, diff on the car and change the motor and trans from the VN to the VR??
    My dad says No because the VN's are slightly different and the motor and shit wouldnt fit, but i thought i would get a second opinion coz i see alot of parts on the internet labeled "VN VP VR VS"
    Anyhelp would be greatly appreciated because i have to get rid of one of the cars asap..
    VP Executive R-spec
    Jan 2005
    Yes can all go in, You will have to use the loom and ecu from the VN, just swap everything in the engine bay and you should be right. Someone in this thread at some point will say "you can't put a older motor in it" so I'll just add a preemptive "bullshit"
    VP Executive R-spec
    Jan 2005
    Although I will add the fixing the VR with another engine and or box would be easier
    vr series 2 v6
    Oct 2009
    nsw
    all thats different is wiring loom and ecu, with the gearbox its cable change gears and the vr are electronic, easy done go for it son
    Vs eco 3.8, extractors, 2.75" exhaust, roller rockers, cammed, bored out 20, t5 manual, rolling on king springs all way round with monroe gt shocks all way round, every door has a ding but looks can be very deceaving
    Dec 2009
    Is it a Series 1 or 2 VN? You should check if there are stricter exhaust emmissions on a VR compared to a VN if there are then you could be defected if someone checks the engine number.
    Also would the instrument cluster still work ok?
    Auzziephoenix's Avatar
    Auzziephoenix is offline Typical P Plater
    Shanghai VZ Calais
    Jul 2009
    if the VR has IRS then no the springs will not fit, because afaik VNs never came in IRS
    but if the vr isnt IRS.. im still not sure if they would, anyone else care to enlighten?
    and the diff yes you can im sure.
    soop is offline Banned
    2003 SS Commodore Series II
    Nov 2008
    Smithton, Tasmania.
    vr series 2 v6
    Oct 2009
    nsw
    Quote Originally Posted by Auzziephoenix View Post
    irs will not fit period
    yes completely the same with suspension wise in the back end, front end is different, as the top struts of ure shocks in the vr has like 8 bolts or something and the vn-vp has 3 bolts, springs would fit the front shocks though if you can change them over by yourself? just keep the front shocks original.\
    brakes are the same, evan for abs as that is in your hub, there is a sensor
    vs commodore
    Oct 2009
    Tamworth NSW
    Vee-ard's Avatar
    Vee-ard is offline QuickVR95II 2010 Survivor
    Foam Tuned VR 5.0l Ute
    5 Miles 2 Go Champion!
    Jun 2009
    Bayswater, WA.
    also putting an older motor into a newer car means it will never pass pits.
    The hall of fame:
    Quote Originally Posted by lindsay.VS.Wagon. View Post
    ....a mini spool creates greater airflow to the engine which means more oxygen into the engine which adds greater combustion which adds an all around performance upgrade.
    Quote Originally Posted by edals View Post
    Also found running your lights all the time looses 100kms to a tank also.
    ಠ_ಠ
    mintvr1994's Avatar
    mintvr1994 is offline get a real DIFF
    vr calais 3.8l
    Jan 2010
    chelsea
    motor and trans should be all sweet but suspension u will have to find out coz some vn's are different
    Nov 2009
    Hey thanks everyone for the help. i found out that i would need to change the Loom in order to change over the motor.. ive opted not to buy the VR and just keep the VN as is..
    Seemed like a good idea at the time :P
    once again thank you all!
  1. [VIC] f.s: vn-vp-vr motor & trans
    By SNAFFLER in forum Parts And Other Items For Sale
    Last Post: 01-09-2009, 10:04 PM
  2. [VIC] EOI: VR V6 motor and trans 167,000km
    By MG's VH Wag in forum Parts And Other Items For Sale
    Last Post: 10-06-2009, 05:01 PM
  3. VP V6 motor+ trans fir directly in vr?????
    By CALAIS 6 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-11-2008, 07:04 PM
  4. VS putting in motor, trans ....anything else?
    By melissanjosh in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-05-2008, 01:51 PM
  5. VH motor and trans into VC
    By Joes_meat in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 08-05-2006, 12:08 AM
Tags for this Thread
