Results 1 to 6 of 6
Thread: VS problems
    Hangman's Avatar
    Hangman is offline Torana Addict
    2 commys, 3 Toranas and a WB Panel Van
    Jan 2010
    Newcastle, home of Toranafest
    Angry VS problems
    My VS has started to run rough so I've checked the codes and got 14-Coolant temp sender low voltage. I reset the codes and now it only shows 12 but is still running like a POS.
    Should I go by the code I did get and replace the sender or could it be something else?
    Cheers.
    Hangman's Avatar
    Jan 2010
    Anyone?
    I need to get it goin asap as it's the family car.
    Any help appreciated.
    Quote Originally Posted by hakhawk View Post
    there are more pressing issues on the site, like choosing between vl's and potatos.
    James39's Avatar
    James39 is offline Gave up on VL's
    1995 VS Acclaim & 1992 Holden Barina
    Jul 2009
    Newcastle NSW
    If it is say the temp sensor, then perhaps you should get another one.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    I'd go with James39's advice and also check the wiring to the sensor. Maybe first do a 1/2 hour run to warm the engine to see if the fault comes back - usually you may get a code for a rich/weak mixture from the O2 sensors if the coolant sensor was giving incorrect info....also may increased fuel consumption.
    Hangman's Avatar
    Jan 2010
    Cheers fellas, I'll try that tomorrow.
    Hangman's Avatar
    Jan 2010
    I ran it up to op. temp. today and it's running ok now. No codes other than 12 come up so I'll see how it goes. Thanks for the replies.
    Not a bad site this, I might stick around. Some nice members cars on here.
  1. Signal Problems Aand LPG Problems
    By reyyan in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-03-2011, 08:33 AM
  2. Ve problems
    By AmC81 in forum VE Holden Commodore (2006 - ?)
    Last Post: 27-10-2009, 11:54 AM
  3. Big problems
    By 5ivespeed in forum Electrical Wiring / Questions
    Last Post: 04-11-2008, 09:54 PM
  4. ignition problems or starting problems
    By Vs-AclaimII in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-10-2006, 04:55 PM
