Results 1 to 16 of 16
Thread: ok BIG OVERHAUL of VR engine, cam, roller rockers and bored
    vr series 2 v6
    Oct 2009
    nsw
    Default ok BIG OVERHAUL of VR engine, cam, roller rockers and bored
    hi got a vr engine been rebuilding, now i have 2 choices, please help me out here guys
    choice number 1
    Crow cam 6071563 (stage 3) $459.00
    Yella Terra rockers $759.00 1.7 or 1.8 rocker ratio.
    Gasket set $215
    Regrind pistons (i mixed them up oops) $230
    choice number 2
    i have been told that cam bearings will eventually spin out and that i have to get the bore checked because things go wrong with them or something along those lines?
    this is all from the blokes at port city engines
    now they said i can do this if i want, send the engine away to them in victoria,
    they will do cam bearings for me,
    they will bore out the bore for $210 (20 though),
    Hypertec pistons, moly rings graphite gaskets, HP big-end main and cam bearings, for $635+gst = $698.50 inc.
    cam
    yella terra rockers
    ALL for $2500, thats incluiding postage and handling, now is this a good price or what? this way the cam bearings have been done and the bores are checked properly.
    how much more power increase will i be looking at with choice 2? how much power will i be looking at with choice 1?
    as i have pod, cai, extractors, 2 1/2 straight through exaust.
    but im gonna do one of them but not sure which one, and also i will need a computer to dial all this in, but tell me what you guys think? power wise im hoping above the 200kw, im hoping, as the cam and roller rockers are 13-17 rwkw increase EACH, so yea thanks again
    Vs eco 3.8, extractors, 2.75" exhaust, roller rockers, cammed, bored out 20, t5 manual, rolling on king springs all way round with monroe gt shocks all way round, every door has a ding but looks can be very deceaving
    Vee-ard's Avatar
    Vee-ard is offline QuickVR95II 2010 Survivor
    Foam Tuned VR 5.0l Ute
    5 Miles 2 Go Champion!
    Jun 2009
    Bayswater, WA.
    200 at the fly or wheels? With an agressive tune you'll maybe see 200 at the wheels. You should make 200 at the fly pretty easy. It's hard to say though.
    The hall of fame:
    Quote Originally Posted by lindsay.VS.Wagon. View Post
    ....a mini spool creates greater airflow to the engine which means more oxygen into the engine which adds greater combustion which adds an all around performance upgrade.
    Quote Originally Posted by edals View Post
    Also found running your lights all the time looses 100kms to a tank also.
    ಠ_ಠ
    vr series 2 v6
    Oct 2009
    nsw
    Quote Originally Posted by Vee-ard View Post
    wow well i think thats at flywheel i was going on, because they are 130 or 135 kw standard, and i would say that is at the flywheel
    thats alot GREAT haha
    whats best way to tune this?
    get a custom chip allready programed,
    or get a programable computer and take it to a dyno? thanks again
    EDIT==you didnt answer my question, would choice 1 or 2 be better? i spose 2 aye?
    VS Berlina 3.8
    Dec 2008
    Quote Originally Posted by peckzz View Post
    Pretty sure your car already has a programmable computer. And please, don't get an ebay chip.
    VP calais, VJ valiant, BG5 legacy
    Jan 2008
    New Plymouth, New Zealand
    IMO Dont bother with high ratio roller rockers if you are getting a decent cam. Just get roller rockers in the standard ratio. Others might tell you different though.
    VS Executive 3.8 Eco
    Oct 2005
    best tune would be to get a mafless tune for it, just a lot more tuning that can be done, but in saying that its also a bit pricey. might wanna talk to delco see what he says
    Jan 2008
    Oct 2005
    Jun 2005
    Quote Originally Posted by Andrew426 View Post
    VRs dont run a MAF anyway?
    Quote Originally Posted by speed_freak View Post
    hence why the conversion is pricey.
    uhhh...explain. VRs run mafless tunes from factory, since they have a MAP sensor
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
    Oct 2005
    ah apologies, i thought was for a vs, in that case a good dyno tune
    vr series 2 v6
    Oct 2009
    nsw
    is delco a company or a bloke like mase on here? please let me know thanks
    will i be best buying a fully programable computer for this and taking it to a dyno tune place? dont they tune the whole computer or what? thanks again
    vr series 2 v6
    Oct 2009
    nsw
    Quote Originally Posted by stocky View Post
    i think they run a delco computer, i have 2 and they have a sticker on them, cant remember if they are delco or not, will check today and update
    Oct 2005
    delco is a bloke on here, hes a good tuner and will make you a nice tuned chipped for only a small fee (if you ask nicely). but considering your trying to squeeze every last bit out of the car i would suggest getting it properly dyno tuned.
    TheForgotten's Avatar
    TheForgotten is offline only human......
    VR EXEC
    Dec 2005
    quarantine
    Delco is company who makes numerous Original Equipment parts for many cars, including the commodore.
    delcowizid is a member on here who can make custom maps for the Delco ECU
    Quote Originally Posted by MY-42-VT
    if they didn't have that thing between there legs we'd laugh and throw rocks at them
    WTB VR/VS FACTORY HEADUNIT BRACKETS PM ME
  15. #15
    vr series 2 v6
    Oct 2009
    nsw
    thanks you know what i want haha yes well i think i will get a dyno tune, what computer will i need for this? standard or not?
  16. #16
    Oct 2005
    im not 100% about the VR's but if your going to go all out i would get a new computer, otherwise im sure you can re map the current computer
  1. Roller Rockers 304 VR
    By Commydoor in forum Yella Terra
    Last Post: 21-04-2011, 11:07 AM
  2. roller rockers/cam
    By PUSHIN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-08-2009, 03:09 AM
  3. [SA] V8 roller rockers
    By Boonz in forum Parts And Other Items For Sale
    Last Post: 16-08-2009, 02:13 PM
  4. Where are my roller rockers?
    By blakeb in forum Yella Terra
    Last Post: 03-09-2008, 06:51 PM
  5. roller rockers
    By tysonsvyss in forum VY Holden Commodore (2002 - 2004)
    Last Post: 18-01-2007, 10:44 PM
