Results 1 to 8 of 8
Thread: chewing thru oil
    04 VZ sv8
    Nov 2009
    Default chewing thru oil
    hey guys i got a 99 vs 5L ute and it seems to go thru engine oil, i changed the oil and filter bout a month or so ago and since then till now i have had to top it up and will need to top it up again kinda soon, its not leaking any where or blowing out black smoke so is this normal for a v8 or have i got a problem with the engine, cheers for any help.
    Mar 2009
    04 VZ sv8
    Nov 2009
    Vee-ard's Avatar
    Vee-ard is offline QuickVR95II 2010 Survivor
    Foam Tuned VR 5.0l Ute
    5 Miles 2 Go Champion!
    Jun 2009
    Bayswater, WA.
    Wow thats a lot. My 5L doesnt even use 250ml over 10000kms.
    Worn rings or valves maybe?
    The hall of fame:
    Quote Originally Posted by lindsay.VS.Wagon. View Post
    ....a mini spool creates greater airflow to the engine which means more oxygen into the engine which adds greater combustion which adds an all around performance upgrade.
    Quote Originally Posted by edals View Post
    Also found running your lights all the time looses 100kms to a tank also.
    ಠ_ಠ
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    The time to be worried about oil consumption is when they blow blue smoke out the tailpipe when you hold the revs at 2500 for about 1 minute on a warm motor......or they leak oil. Otherwise anything up to a litre per 2000km would be OK with me.
    Thicker oil will reduce consumption.
    VP BT1 & BLOWN STATESMAN
    Oct 2005
    Quote Originally Posted by ryan86 View Post
    You might of used the wrong oil for it????
    NEVER LATE IN A 355ci
    04 VZ sv8
    Nov 2009
    nah i doubt i used the wrong oil, i used the castrol GTX3, went thru there booklet thing and thats what they reccomended
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    GTX3 is 15w40 which is a thin oil - you should be using 20W50 which is what the manufacturer designed the engine to use - that's what the owners handbook says...... Castrol may say to use it but I'd rely on the people who made the car! Use of a thinner oil will increase oil consumption.
  1. which models had tyre chewing problems?
    By ascension24 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-01-2009, 10:55 AM
  2. Tyre chewing problem solution
    Last Post: 12-06-2006, 04:03 PM
  3. Chewing Out Rear Tyres
    By Brumbies 5L in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-02-2006, 11:26 AM
  4. Series 1 VS chewing oil
    By Scooter79 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-08-2005, 06:25 PM
  5. Chewing up fanbelts
    By Rickvsv6 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-02-2005, 09:34 PM
