Hey all, I need to remove my back seat out of my VS Equipe to replace the LH seat belt assembly. I am having trouble getting the seat out; Is there a method to removing the seat or is it just a matter of sheer brute strength??
Thanks in advance, Cheers Rossco
you gotta push the seat hard to the boot direction and it should clip out may take a bit of effort
brute strength dosn't replace brute strength, what you need to do is lift the bottom part of the rear seats enough to get your hand underneath it, then wiggle it forward, the bottom half will simply then come off...
then with the top half you'll need to unbolt the screws holding them in. these are located down the bottom there are 2 i believe...
once undone, lift from the bottom and they'll simply unhinge... to put back on do this in reverse...
nb. take your time mate
Good luck!
Give this a read, it should tell you how to get the backs out.
VT/VX RetroFit Guide for: VN/VP/VR/VS
Thanks guys, all done now. It is easy once you know how to do it hey.
Cheers and thanks again!
