Im having some problems with what seems to me the electrics of my 1994 Commodore V6, the hazard lights, demister and air con buttons all wont work for some reason and neither will the fan for my air con. Any suggestions for a quick fix?
Check for blown fuses,stuffed relays and wiring for bad connections.Fuses and relays are both under the dash near the steering column, and under the bonnet.
hazard lights either globe is burned need a new 1s or could be due to the turn switch by the steering wheel is loose its a comon problem even with mine i had to take apart the dash an check it out put it back together should be fine... as for air con hopefuly its not a big problem posibly could be because the air con has no gas may need a refill or the fanbelt was taken off hopefuly it hasnt stoped working all together...
Could be something as simple as the connectors, they could have come loose. You haven't had the dash apart at all? It seems strange that those things don't work, they are all next to each other.
