Results 1 to 4 of 4
Thread: replacing BCM/ programming new key head- VS
    GTP 85's Avatar
    GTP 85 is offline 291 hp @ the wheels
    VS track car & VS SSenator
    Aug 2006
    Adelaide, near the bay
    Default replacing BCM/ programming new key head- VS
    Advance apology, posted this in electrical sections but got no replies. MODS please delete the other thread if you wish....
    Just looking for a straight answer to this one, thanks!
    Bought a VS berlina rolling shell, minus running gear and a few interior bits.
    NOW... the previous owner took the BCM and the key head off the key. I have a spare VS berlina BCM at home from a wrecked car, is it as simple as programming a new key head to the BCM i have and plugging in and off i go??
    I have no idea about this stuff so please help me if you can
    Thanks
    Hit me up with some reputation points if i've helped you out! (Star in the bottom left!) Cheers!
    GT Performance RUF 231- NA 3.8L- 13.30 @ 103 Mph... So far... Cam, compression and revs! MY CAR>> http://forums.justcommodores.com.au/...tml#post471410
    Daily VR SS: http://forums.justcommodores.com.au/...ite-vr-ss.html
    vs commodore
    Oct 2009
    Tamworth NSW
    You will need the BCM code programmed into a new keyhead.Holden can usually get this code online through your VIN number,I dont know how it works if you have changed your BCM because it wont match your VIN any more.Unless Holden can change the BCM code to match your VIN,then program the key as well.
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    you need the vin number off the orignal bcm's vehicle, unless you have the key for that bcm or know the origan of the bcm (orignal vehicle) you mayas well use it as a door stop
    VR Caprice
    Dec 2005
    Go and have a talk to either Holden or if you have a mister mint near you. When you get a Keyhead from Mr Mint they only put a generic programme in the keyhead, you then go through a process after putting it in your ignition and the BCM upgrades the keyhead. They need your Model and Year for this.
  1. replacing BCM/ programming new key head- VS
    By GTP 85 in forum Electrical Wiring / Questions
    Last Post: 14-01-2010, 03:11 PM
  2. Programming New Key Head
    By mr_v8 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-12-2006, 10:15 PM
  3. Replacing Head Gaskets
    By sparkymac in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-12-2006, 09:19 AM
  4. replacing head unit
    By vt com in forum Car Audio
    Last Post: 19-11-2006, 05:46 PM
  5. Programming Eurovox Head Unit in VP
    By wolfman in forum Car Audio
    Last Post: 04-10-2004, 02:31 PM
