Results 1 to 18 of 18
Thread: best aftermarket spark plugs and leads? [VR V6]
    nathanVY's Avatar
    nathanVY is offline need boost...
    03 VY Calais, 99 VT Equipe
    Dec 2009
    Geelong, VIC
    Red face best aftermarket spark plugs and leads? [VR V6]
    hey everyone, I have to change the spark plugs and leads in my VR,
    wondering if it's worth getting performance ones?
    what brands are good, types etc
    anything else I should be doing when I change them?
    thanks
    I have 2 cars VZ sv8 6 litre and VU ute 5.7 litre
    Sep 2008
    Quote Originally Posted by nathanwright View Post
    thanks
    try these EURO BRISK MULTISPARK SPARK PLUG [ HOLDEN COMMODORE ] - eBay Spark Plugs, Ignition, Charging, Car Parts, Accessories, Cars, Bikes, Boats. (end time 22-Jan-10 20:34:55 AEDST)
    calais24/7's Avatar
    calais24/7 is offline Mucca Mad Boys
    VS Calais II 5L, 98 rodeo v6
    Jul 2009
    IMO I wouldn't worry about buying 'platinum' plugs that are like 20 bucks each instead just use ngk or bosch. However those are pretty cheap ^ but i have never heard of them.
    nathanVY's Avatar
    Dec 2009
    Geelong, VIC
    what kinda difference would it make? theyre bloody expensive, it would wanna be worth it. i'd do it if I never had to replace plugs again
    Sep 2008
    Well there one way to find out and that's try them if you cant afford it stick with what you've got.
    VR 304
    Mar 2009
    Wont make any difference, unless you a got a race car, in wont go any harder with special 10mm Top guns leads or irridium plugs.
    Just run the genuine bosch plugs and leads as they are also a Better Fit.
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    just use standard ones, i tried some of the other types of plugs but just went back to stock, not worth the money, same with leads. I just buy the stock bosch plugs and leads from supercheap. You can't ignite fuel more than it already is.
    nathanVY's Avatar
    Dec 2009
    Geelong, VIC
    yer I will considering i've gotta do the bloody rear main seal.
    thanks for the advice.
    vr commodore
    Nov 2009
    umina nsw
    you can get the bosch platinum plugs from most repco stores for about the same price as standard ngk plugs. im running the bosch fusion plugs in my vr, they come in at roughly the same price as ngk iridiums
    VS_Pete_1's Avatar
    VS_Pete_1 is offline Donating Member
    VE II SV6 MY12 Sportwagon
    Dec 2007
    ACDelco from holden part number AC8.
    Cheap and good and you will notice some difference.
    $8.80 retail I checked today
    "Success is the ability to go from one failure to another with no loss of enthusiasm" Sir Winston Churchill.
    My VS II Berlina Wagon
    MY12 II SV6 Sportwagon
    VS_Pete_1's Avatar
    Dec 2007
    2000 VT BERLINA LS1 by design
    Oct 2009
    for your leads, i would say find some 8 to 10mm stainless leads.
    i used to run 10mm top gun leads in my vt supa6. also msd coil packs go alright.
    but if ur not lookin for supa fast passes then stick with bosch. they are quality and great price.
    Current Ride: VRll 5Spd Poverty Pack
    Previous Rides: 99 VT2 Super 6. (too much too list. was off its head$$$$$$$$)
    nathanVY's Avatar
    Dec 2009
    Geelong, VIC
    Quote Originally Posted by njb1988 View Post
    cool thanks, i'm keen for a bit of performance boostage. can you explain what coil packs are and
    if they are easy to change, etc
    Oct 2009
    they are the round things that ur leads run to from ur plugs. 2 nuts on each, and then they lift straight off. easy as to do. from memory i think mine were about $400 for all three.
  15. #15
    nathanVY's Avatar
    Dec 2009
    Geelong, VIC
    yeah pretty expensive, i don't think ill go for the performance ones here, i'd rather put that money in to better mods, exhaust or something.
  16. #16
    VS 3.8l Exec
    May 2006
    Ya mums house!!!
    I would suggest the standard NGK plugs are fine, I had platnium bosch and I never felt and difference in reliability. As for leads make sure you get the leads with the sheild and angle type connection. As the ones designed for the VN's and VP's are a silcon straight connection type that get very bloody hot and in my experiance tend to fail more often than those with the heat shields and are a angle type connection... I can get pics if you need more explaination!
  17. #17
    nathanVY's Avatar
    Dec 2009
    Geelong, VIC
  18. #18
    VS 5.0 BT1
    Aug 2009
    I got Magnecor leads on mine (V8 but) 8.8mm and you get a 10yr replacement warranty.
    They were a bit pricey though but with that sort of guarantee I'm pretty happy, stuck with the plain jane Bosch plugs.
    Running LPG (+Crane Cam, zorst, etc, etc) and have had no probs at all.
  1. spark plugs and leads...
    By ryan86 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-12-2009, 10:26 PM
  2. Which Spark Plugs/Leads
    By sweefu in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-03-2009, 08:37 PM
  3. Spark Plugs and Leads
    By BANKS in forum General
    Last Post: 03-05-2008, 10:37 PM
  4. Spark plugs and leads
    By GROWLZ in forum General Discussion
    Last Post: 25-06-2006, 04:30 PM
  5. Spark Plug Leads Getting 'baked' on to Spark Plugs?
    By holden#1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-09-2005, 04:16 PM
