Results 1 to 7 of 7
Thread: Auto Shudder
    VN Wagon
    Jan 2010
    Default Auto Shudder
    Hi just bought a VS commodore very happy with it besides the fact when sitting at the lights it will shudder and feel real notchy until you lift your foot of the brake and go agian and its fine. The auto dosent slip at all, and change gears smoothly, If any one will know what causes this help would be greatly appreciated Cheers Cam
    vr series 2 v6
    Oct 2009
    nsw
    sounds like your brake booster, or you need to reset your ecu so it might set the idle, what revs is this doin when your at lights?
    Vs eco 3.8, extractors, 2.75" exhaust, roller rockers, cammed, bored out 20, t5 manual, rolling on king springs all way round with monroe gt shocks all way round, every door has a ding but looks can be very deceaving
    VN Wagon
    Jan 2010
    vs commodore
    Oct 2009
    Tamworth NSW
    The brake booster is probably stuffed and letting air get in past its seals or valves,which will make the engine run rough because the brake booster uses vacuum from the engine to work.Hows the brake pedal feel to push in,hard or normal?
    VN Wagon
    Jan 2010
    Nah Brakes are fine dosent lose pressure at all feels like normal commodore brakes
    vr series 2 v6
    Oct 2009
    nsw
    Quote Originally Posted by CAMZVS View Post
    revs at bout 500 with my foot on the brake
    try reseting the ecu
    best way for this is to disconnect the main 60 amp fuse which is 2x10mm botls holding it in, and of course disconecting the battery as well
    but others say just leave the battery off for 5 mins does the same, but up to you, just give that a try, and if thats not it, its your brake booster
    VN Wagon
    Jan 2010
    thanks for the help guys ended up been one engine mount and the transmission mount cause every thing to rattle and shake cheers cam
  1. shudder around 80 k's
    By stumpy03 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-07-2009, 12:03 AM
  2. Shudder
    By jyothi in forum VY Holden Commodore (2002 - 2004)
    Last Post: 12-06-2009, 05:19 PM
  3. serious shudder in my vy ss m6
    By turtle13 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 14-05-2009, 07:00 PM
  4. Shudder
    By hazza in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-03-2009, 06:06 AM
  5. bad shudder
    By 2greedy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-03-2007, 10:12 AM
